4x4 vacuum switch problem?
Old Jun 7, 2011 | 07:07 PM
Crewcab Turbo's Avatar
Crewcab Turbo
My 2000 auto 4x4 hubs are not locking. I replaced the line going to the driver side wheel. It looked like a soaker hose for watering the lawn. I turn the switch on the dash and the 4x4 light comes on the dash, the driveshaft locks in the transfercase, but no vacuum at the wheels. Checked the vacuum switch on the fender and it has vacuum going in but it is not switching vacuum. Now the questions! Is there a fuse that would control the vacuum switch separately from the 4x4 light? Anyone have a wireing diagram or advice how to test it further? Any help would be great! Thanks all in advance.
Old Jun 7, 2011 | 08:00 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
You have a vacuum leak. I have an active thread on it. This thread has many different ways to diagnose it. Read this and see what you find:
https://www.ford-trucks.com/forums/1...-question.html
Old Jun 7, 2011 | 08:41 PM
Crewcab Turbo
My vacuum switch is under the hood on the passenger firewall it has plenty of vacuum going into the switch butt nothing coming out. I think the switch is not getting it's signal voltage or ground. Or vacuum switch is bad! Not sure? I may have a vacuum leak after, Aka soaker soaker hose.
Old Jun 7, 2011 | 08:43 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Switch into 4x4 and run over to that side of the engine, if the motor is on, there is a leak after the pump. If the motor is NOT on, then get a test light and find out if there is a signal coming into the pump, if there is a signal coming in then the pump is bad.
Old Jun 7, 2011 | 08:47 PM
Crewcab Turbo
Pump works great I have good vacuum coming out of the Vac resivuar (cant spell) and going into the 4x4 Vac switch.
Old Jun 7, 2011 | 08:48 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Check your vac switch wiring and all associated tubing. How are you measuring vacuum?
Old Jun 7, 2011 | 08:55 PM
Crewcab Turbo
I have a Vac Gage and I didn't check what's going into the switch butt it sucks good . I tested what's coming out and it's a big 0 no matter what. Think I need the wiring schematic to b able to test the wiring coming into the switch.
Old Jun 7, 2011 | 11:48 PM
MR5x5's Avatar
MR5x5
Sounds like the vac switch on the fender is shot. Had the same thing happen to me. $50 at the dealer.
Old Jun 8, 2011 | 01:20 AM
Bitterbeard's Avatar
Bitterbeard
Wait what? Our trucks have auto locking 4x4 hubs? I thought my 2002 f350 was all manual, I got some rims that cover the hubs and I dread the next time I need 4x4 action I'll have to get out the allen wrench in the snow and go to work...
How do you check if your truck even has these?
Old Jun 8, 2011 | 01:30 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Take your hub caps off.. the auto locking hubs will look like this. (just leave your hub caps off.) chances are your auto hubs need some maintenance (as you see us discussing here)
Old Jun 8, 2011 | 06:18 AM
Crewcab Turbo
Bitterbeard u can check by looking at your front wheels . You will have 3 lines instead of two going to each front wheel. One is your brake line, one is your abs line, and the other is the auto hub line. The auto hub line connects to a hose barb on the inside of the knuckle.
Old Jun 8, 2011 | 12:55 PM
Bitterbeard
Yep, I've got auto locking hubs. Mine look nowhere near as nice as Trey's, I think the previous owner used them to clean his boots off or something before getting into the truck. I'll need to tear them apart following Guzzle's walk through, once again thanks to FTE for the info!
Old Jun 8, 2011 | 08:19 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I posted an update to my thread.. I fixed the problem on mine. Pics included..
https://www.ford-trucks.com/forums/1...l#post10438226
nddragon01
2004 - 2008 F150
Feb 7, 2017 07:18 PM
johnlatt09
Jan 21, 2017 04:00 PM
Capt No Slack
2004 - 2008 F150
Jan 6, 2017 07:58 PM
Akflyboy
Dec 13, 2016 01:44 PM
deputydog03
Dec 10, 2015 07:40 PM
