Fuel filter
Old Dec 24, 2009 | 10:51 AM
  #31
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Originally Posted by flashart24
Every one is right about the price. I use the NAPA golds and only pay $62 , as far as changing the filter , a couple of long extensions will carry you out to the fuel tank and there you have plenty of room to get the leverage you need. Also please up grade your plug.
Napa/WIX fuel and oil filters are NOT OEM spec'd for the 6.0L PSd motor.
Racor is the OEM manufacture and they designed the housing (oil and filter) to accept their filters ONLY and safely. Others have tried to copy the filters and some do fit...but buyer beware!!!
You stated above that you paid $62.00 for the fuel filter kit... and I know for a fact that it is NOT OEM made (may look similar but not OEM). You can buy OEM fuel filters at any Int'l truck dealer/center and pay 1/2 that... and get OEM performance for less money... so why risk it.
My local dealer sells them for around $70.00/kit... so if your willing to spend that amount of money ($62.00)... spend a few more and know your getting OEM quality from Racor (The OEM designed of the fuel and oil filter housings).
You can order these fuel filters on line from distributors that ONLY sell OEM filters (someone here will post a link)... and they will be less than the $62.00 you spent.
Just want you to know that you have options that will cost you less and give you better quality.
Old Dec 24, 2009 | 01:08 PM
  #32
foolforfords's Avatar
foolforfords
Fuel Filters at Autozone $$$$
on my last filter change I used fuel filters from auto zone, Luberfiner Filters with no problems at all.even compared them to napas filters they were cheaper at auto zone $49.00 for filters, $63.00 @ napa just my 2 cents by the way merry xmas all..... FFF
Old Dec 24, 2009 | 02:19 PM
  #33
D8chumley's Avatar
D8chumley
Resident smarta$$
Ford 6.0 Liter Turbo Diesel Motorcraft FD-4604 Fuel/Water Seperator Filters(FD4604): Pick Up & Excursion Notice the aquabloc membrane on the HFCM filter. If YOU want to take chances with water making it to your injectors, then good luck to ya. Me personally, I'll stick with the correct 3: Fuel, filters and fluids. EDIT: http://www.dieselfiltersonline.com/P...-Pff-4604.aspx Racor is @ $10 cheaper, only $35
KLINE925
Apr 3, 2014 01:29 AM
f150crewcab
Jun 25, 2012 12:05 PM
teamgsxr
Dec 9, 2011 10:49 AM
Gearitis
6.4L Power Stroke Diesel
Jan 30, 2011 04:15 PM
bocomojoe
Jul 10, 2005 11:52 AM
