Cleaned HFCM - bye bye red goo
Old 06-25-2012, 10:10 AM
f150crewcab's Avatar
f150crewcab
f150crewcab is offline
My water-in-fuel light has been on constantly since I bought my 6.0L X about 3 weeks ago. Replaced fuel filters immediately; used DieselKleen in fuel; drained the HFCM multiple times...no water (upgraded the HFCM plug too). Sprayed some carb cleaner through drain hole and out runs red goo. Finally had time to clean out the HFCM this weekend.
  1. Raised front-end on ramps, chocked wheels.
  2. Attempted to remove front drive shaft to 4x4. Couldn't free one of the bolts on the front U-joint. Rats.
  3. Since I couldn't remove the drive shaft, there wasn't enough room to remove the entire HFCM, so I removed only the cover.
  4. Disconnect battery.
  5. Unplug WIF sensor and fuel heater.
  6. Drain HFCM (again) to make sure it's empty...it wasn't.
  7. Disconnect 4 fuel lines. Wipe fuel from running down arms. I should mention that I had less than 1/4 tank of fuel to try and minimize spillage.
  8. Remove 4 cover screws (7mm, though my 5/16" SAE socket fit better.)
  9. Clean cover and HFCM with carb cleaner.
  10. Replace HFCM gasket.
  11. Replace HFCM cover; screws were hand-tightened.
  12. Reconnect fuel lines and sensors.
  13. Cycle Key-On, Engine Off (KOEO) about 4-5 times.
  14. Crank 'er up....no more WIF light.
Here are some before and after pics.
BEFORE:
AFTER:
Old 06-25-2012, 10:12 AM
f150crewcab
One more thing: I wouldn't have attempted, much less couldn't have done it without tips and other how-to's on FTE. Thanks guys!
Old 06-25-2012, 11:34 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Nasty stuff!
Was it mold?
Old 06-25-2012, 12:05 PM
f150crewcab
Not sure if it was mold or algae. Nasty for sure!
zed326
1999 to 2016 Super Duty
07-17-2014 01:50 PM
spdmpo
106
04-10-2014 03:34 PM
yukonsce
6.4L Power Stroke Diesel
02-11-2013 09:41 AM
srkr
07-21-2010 10:50 AM
lionsteve
08-26-2008 09:31 PM
Quick Reply: Cleaned HFCM - bye bye red goo
