Towing Mirrors
Old Dec 18, 2009 | 04:09 AM
skidoos's Avatar
skidoos
Towing Mirrors
I bought a 2009 ford f150 xlt back in september and it came with basic side mirrors no heat and no turn signal . I saw on a old post about Tasca parts towing mirrors that pull out with turn signal and heated looks like a great price my question is do these trucks come prewired and is it a plug and play . Do i need to buy the button for the dash and is the harnes behind the dash already . Dealer won't give me a straight answer . Thanks for any help . skidoos
Old Dec 19, 2009 | 04:17 AM
skidoos's Avatar
skidoos
No One can help
Old Dec 19, 2009 | 07:33 AM
skywagon's Avatar
skywagon
No One can help
Skidoo, I have not jumped in this thread because I am not sure. We went thru this and put towing mirriors from Tasca but had the heated and lighted mirriors from the start. now from what we have seen, Ford is good about installing a complete harness for all accessories and if you buy a switch for the dash should be plug and play. if they do not use a certain accessory they just leave the wire hang. If it were me I would try get the switch and take the Bezel off and look for the harness connector that will match the switch terminals. I am very surprised a Ford tec cannot tell you the answer.
Old Dec 19, 2009 | 07:17 PM
Greg B's Avatar
Greg B
You may have to buy the switch for the dash and the relay in the fuse block for heated mirrors. It should already be wired for it, though. I bought the 07 tow mirrors for my 06 and it wasn't wired for heated or puddle lamps. Everything else works, though.
Old Dec 20, 2009 | 05:36 AM
skidoos's Avatar
skidoos
Thanks for the replys.
Old Dec 21, 2009 | 05:59 PM
Paulford8's Avatar
Paulford8
I need to do this upgrade also as I do a great deal of towing.. Was the install fast and easy for you? I have neat/lighted mirrors now... I was going to buy from Tasca and jump head first into it.
Old Dec 21, 2009 | 06:08 PM
skidoos's Avatar
skidoos
I did not do it yet . I was told that i need the wire harnes buy ford and the swicth does not come seperate for the heated mirror you need to buy the whole control for like $300:00 .I don't think so . If you do do yours please let me know how you made out because I cant get a good solid answer from anyone . Good luck skidoos
Old Dec 21, 2009 | 06:12 PM
skywagon's Avatar
skywagon
15-20 minutes per side, if you aqlready have heated lighted mirriors it is plug and play.
Old Dec 21, 2009 | 07:18 PM
Greg B's Avatar
Greg B
It took me about 45 minutes for the driver side and 20 minutes for the passenger side. It took me a little longer to figure out how to get the door panel off without breaking anything and I had to figure out which wire I had to move in the harness to have things work. All in all, it was easy.
Old Jan 4, 2010 | 11:25 PM
mdbill's Avatar
mdbill
I have a set of tow mirrors that came off my Platinum. If anyone is interseted in buying them, let me know.
Bill
Old Jan 5, 2010 | 03:52 AM
skidoos's Avatar
skidoos
Thanks but I have a pair already comming in the mail should be here today from Tasca Parts . skidoos
Old Jan 5, 2010 | 05:08 AM
Dark_Wizard's Avatar
Dark_Wizard
Bill
How much and are they all black?
Old Jan 5, 2010 | 02:01 PM
mdbill's Avatar
mdbill
$300.00 AND THEY ARE CHROME SKULL CAPS.
BILL
Old Jan 5, 2010 | 02:33 PM
rock_meg's Avatar
rock_meg
BILL
Hi Bill, I just sent you an email!!!
Thanks
Rock
skidoos
2009 - 2014 F150
Jun 15, 2018 07:45 AM
birdnut
Feb 1, 2013 06:50 AM
illini5190
Dec 15, 2010 05:58 AM
skidoos
2009 - 2014 F150
Jan 8, 2010 12:51 PM
billygoat
Jan 17, 2007 08:10 AM
