Puddle Lamps
Old Jan 16, 2010 | 02:47 PM
skidoos's Avatar
skidoos
Puddle Lamps
Just installed tow mirrors but never had wire for puddle lamps how is everyone doing theirs. Need pins for connector were to buy and were do you tie into i have a 2009 xlt , Thanks skidoos
Old Jan 18, 2010 | 10:47 AM
aliva's Avatar
aliva
Puddle Lamps
I installed them on my 09 Screw. The wire should be in the original harness to the mirrors. I believe its the purple wire. There should be 12v on that wire when the interior lights are on. If not then you'll have to see a dealer to reprogram the SJB ( Smart Junction Box). My dealer was advised by Ford that they don't support the reprogramming because the truck was never equipped withe lights from the factory. To get around this I connected a wire from the overhead interior lights thru the door up to the puddle lamps. Works fine. I did not use original Frord puddle lamps, I used 20 watt 12v pot lamps. They just happen to be the correct size to fit in the blank covers in the mirrors. The Ford p/n for the lamp is 13B375. I do have some pics if your interested, just send me a pm and I'll email them to you.
Hope this helps
Old Jan 18, 2010 | 11:30 AM
Dark_Wizard's Avatar
Dark_Wizard
Pot lamps? How did you get the mirror apart to add the wiring? I would like to see the pics as well...thx!
Bob
Old Jan 18, 2010 | 01:18 PM
aliva's Avatar
aliva
Since the administrators won't allow me to attach anything to my post, and I can't pm anyone I've uploaded pictures to the Albums under Puddle Lamps. Hopefully this will answer most questions. If not I'll check back here on a regular basis.
Old Nov 14, 2017 | 07:22 PM
Fordtruckman1992's Avatar
Fordtruckman1992
Hey everyone, new member here....I have a 2011 f150 king ranch and I have a issue with the puddle lights. The passenger side light works but not the drivers side...tried new lights and that did not work. Can anyone help? Wondering if it's a ground issue but don't know where to start. Thanks!
Old Jun 14, 2018 | 09:50 AM
Rudiak's Avatar
Rudiak
Subscribing
Old Jun 15, 2018 | 07:45 AM
mueckster's Avatar
mueckster
I found the correct size and style pins in a radio adapter harness kit at Walmart. I can't find the package, right now, to give you a part number.
Bugzilla46310
Feb 3, 2020 04:32 PM
86eddieb
2015 - 2020 F150
Jun 7, 2019 01:28 PM
A/Ox4
2009 - 2014 F150
Dec 27, 2016 08:53 PM
A/Ox4
2009 - 2014 F150
Dec 2, 2016 01:12 PM
dougasy
2009 - 2014 F150
Nov 29, 2016 07:42 PM
