when to use engine block heater!!
Old Dec 15, 2009 | 03:35 PM
Pitcher's Avatar
Pitcher
I just bought a cord for my 06 at O'Riley's for $19, however I am not sure the connection is good. What temp does it actually warm it up to? Will you actually notice it on the temp gage?
Old Dec 15, 2009 | 03:45 PM
IHbase's Avatar
IHbase
10. Not windchill 10, 10 ambient. Sure, you COULD plug it in when it is not cold- pretending that you are helping your truck, but you could plug it in at 70 too- at some point you are just wasting money and being silly.
In Minnesota, I always plugged my trucks in. My neighbors NEVER plugged their trucks in. Did it matter? I doubt it- their trucks ran until they were traded.
Seems like a lot of what we do is just preserving our truck for the next owner...
-mike
Old Dec 15, 2009 | 04:30 PM
zhilton's Avatar
zhilton
On mine the needle is just off the "cold" end of the temp range. I'm not running a/m gauges (yet), so I don't know what temp it is. I know the one I had in a T800 would keep the coolant about 120F (according to the KW gauge).
Old Dec 15, 2009 | 05:20 PM
gunnarGSD's Avatar
gunnarGSD
I have noticed from this and previous threads re block heaters is that it seems that the warmer the climate a person is from the sooner they plug in thier trucks. Living up here in Canada most people I know don't plug in thiers trucks until about -10 to -15 celcius, or 14-5 F. I personnal don't plug in unless it is forcasted to hit -15C. I fire it up let it idle for a minute or two or long enough to scrap windows and drive away, gentle of course until it comes to operating tempature. Now to each his own, but you certainly won't be hurting your truck if you don't plug in unitl around 20-15 and will probably save a few bucks in electricity.
Old Dec 15, 2009 | 05:24 PM
gearloose1's Avatar
gearloose1
Block heaters are at best, 15amp, and typically, 10amp or less, or 1,000 watt range.
That is very little heat and it dissapates very quickly in the cold.
Hence, not much difference once the block heated area stabilizes and reaches peak temperature --- probably 3 to 4 hours.
Old Dec 15, 2009 | 06:17 PM
bismic's Avatar
bismic
I have heard of several studies that claimed it saved money to use the block heater on cold mornings because the fuel economy did not take as long to come up to the "typical" value. The theory being that electric heat was cheaper and more efficient for the heating up of the engine block, etc. than the cost of diesel - pretty much like zhilton was saying.
Old Dec 15, 2009 | 06:39 PM
gearloose1's Avatar
gearloose1
325 hp (242 kW) is the rating of the engine.
For arguments sake, say it is running at 3 kw at idle.
More likely than not, accessories, including the alternator, require more than that to be generated.
That is at least 2 times the output of the block heater.
True, not all of that is being converted into heat for the engine --- but into mechanical energy, motion, electricity, etc...
But at idle, most of that is heat, some electricity for alternator, cooling fan.
If you are driving with it, power output is at least 10% of capacity, or 25 to 30 kw.
Way more than a block heater.
True, in most locations, electricity is cheaper than running with diesel fuel to generate heat.
But have no doubt that your engine dwafts the output of your household electric circuit.
A good block heater MIGHT draw 900 watt, and an oil pan heater another 500 watt.
Peanuts --- that is why real truck heaters use diesel.
Typically, most homes today have 120amp service, some 200amp.
That is still tiny compared to the output of the 6.0 going at, say, 70mph.
Old Dec 15, 2009 | 10:35 PM
zhilton's Avatar
zhilton
<snip>
I think for the sake of all our sanity...and maybe one of these Block Heater thread will get blazed in LARGE RED letters across the top of all the diesel threads. Block heaters are like engine oil....to each their own. If you want to run it...great; if not...no big deal. Yeah you might help the engine out on a cold morning, but I'm sure you ball-the-jack on it some where down the road and the damage is done any way. The engine is only going to go so long with your driving style. You might get an extra 1k miles (out of 300k-500k) by plugging it in at night; maybe something totals the truck out before you find out. PLEASE, lets bury the hatch on this one; though I'm sure someone will ask after Christmas "when should I start using the block heater"...or "where is the block heater on my truck". And knowing my stubborn self, I'll jump in and offer advice instead of pointing someone to this thread...or one of the other half dozen that are on here
Old Dec 15, 2009 | 11:02 PM
olfordsnstone's Avatar
olfordsnstone
Don't forget, plugging in at higher than REALLY cold temps also makes starting up a little easier on the batteries. Over time, that would equate to a cost savings there too as you would get a bit longer life out of them.
If I think it might get cold overnight I just go ahead and plug her in. Can't imagine it would hurt anything, only help. Oh yeah, I also have a digital timer mounted on my exterior garage wall facing where I park overnight. That way I can have it set to turn on the block heater 3-4 hours before start up time.
Old Dec 15, 2009 | 11:20 PM
Pitcher's Avatar
Pitcher
For those of you that have used your block heater: do you notice a difference on your gauge? or does the heater just bring it up a few degrees?
Old Dec 16, 2009 | 05:13 AM
dschuffert's Avatar
dschuffert
My cage is still in the Cold area when I start it, no difference than when not using it, but it does climb the gauge much faster than if I didn't use it.
Old Dec 16, 2009 | 05:55 AM
Pitcher's Avatar
Pitcher
Thanks dschuffert!
I was wondering if it was working or not...
knightrider955
6.2L V8
17
Feb 3, 2025 06:13 AM
pickerdd
Apr 18, 2017 07:10 AM
sunuvabug
Mar 16, 2017 07:23 AM
cowmilker08
21
Feb 15, 2012 10:47 PM
wmiller
35
Nov 23, 2008 06:51 PM
