Engine Block Heaters
Old Feb 16, 2017 | 12:36 PM
pickerdd's Avatar
pickerdd
Does anyone know if the engine block heater is automatically installed in the SD's? I've heard various reports that the heater is automatically installed, but you don't get the AC cable unless you specifically order the Engine Block Heater with a new truck.
My dealer was supposed to order it, but missed that option when they placed my order.
Thanks.
Old Feb 16, 2017 | 12:41 PM
AK_SuperDuty's Avatar
AK_SuperDuty
The dual extra heavy duty alternator, block heater, and supplemental cab heater are standard (on the diesel) with no additional charge to 16 colder, more northern states. Up in Alaska, you can't get a 17' 6.7 through a dealer without these things. Down south in the rest of the states, you have to specify these on your order. And you have to pay more for them
Old Feb 16, 2017 | 01:09 PM
Sleepyguy's Avatar
Sleepyguy
In canada they are standard equipement.
Old Feb 16, 2017 | 01:24 PM
kry226's Avatar
kry226
Not sure this gentleman's question has been answered. As an example, every Cummins engine to be installed in a Ram leaves the factory with a block heater installed regardless of final destination, but not every truck comes with the power cord.
So, does this gent simply have to buy a power cord to connect to the block heater's terminal on the block, or does he need to buy an actual block heater element and install it into the block?
I'm simply not as familiar with Powerstrokes as I am with a Cummins to provide the correct answer.
Old Feb 16, 2017 | 01:30 PM
fordmantpw's Avatar
fordmantpw
The block heater is NOT included. You have to buy the heater element and install it into the block if the truck is not ordered with it.
Old Feb 16, 2017 | 01:32 PM
pickerdd's Avatar
pickerdd
OK, thanks for the clarification. Much appreciated!
Old Apr 15, 2017 | 01:38 PM
kevinstoy's Avatar
kevinstoy
does a 2011 F 350 Diesel have a sensor on the block heater so it won't work above a certain temperature are will it work anytime it's plugged in ? I tried testing it but it's 80 degrees and it isn't turning on.
Thanks
Old Apr 15, 2017 | 03:01 PM
crewzer's Avatar
crewzer
Lightbulb
Originally Posted by kevinstoy
does a 2011 F 350 Diesel have a sensor on the block heater so it won't work above a certain temperature are will it work anytime it's plugged in ? I tried testing it but it's 80 degrees and it isn't turning on. Thanks
It's about 78F at my house this afternoon, and my 2017 F350 6.2's engine block heater fired right up when I plugged it in through my Kill-a-Watt meter. The pic below shows a 370W load.
If yours isn't working, I'd confirm that your extension cord, outlet (GFI protected?), and circuit breaker are all OK. This is purely speculation on my part, but due to the diesel's larger thermal mass, I wouldn't be surprised if your engine's heater draws more power.
HTH,
Jim / crewzer
Old Apr 15, 2017 | 03:11 PM
Litre's Avatar
Litre
Cold-states (snow belt) and Canada gets the 2 alternator, engine block heater and supplemental cab heater standard. Every SD in Idaho had them when I was shopping. Dealer confirmed
Old Apr 15, 2017 | 03:29 PM
Sleepyguy's Avatar
Sleepyguy
GMC has the thermal trigger on it. Fords will run not matter what and a diesel heater draws a ton more. Exactly how much I am unsure but three in one plug is enough to blow your standard house hold breaker which is 15 amps?
Blowing breakers due to block heaters being plugged in is very common at work. It's like a dance who can park where. Too many diesels in a row and run out of plugs!
Old Apr 15, 2017 | 03:30 PM
Sleepyguy's Avatar
Sleepyguy
Double post
Old Apr 16, 2017 | 12:09 AM
BII Plow Truck's Avatar
BII Plow Truck
Thanks
Time to replace the cord.
Old Apr 18, 2017 | 07:10 AM
milkweed.gardener's Avatar
milkweed.gardener
The way I read the Super Duty owners manual is that the engine block heater will run as long as it is plugged in. This is how my Jeep's engine block heater worked, if I wanted it to stop heating I had to unplug it.
mblayton
Ford Truck Parts for Sale
Jan 9, 2017 05:53 PM
2gumby2
2015 - 2020 F150
Apr 6, 2016 11:30 AM
knash0727
17
Dec 4, 2009 10:26 AM
Big D
Dec 29, 2007 07:34 PM
CrazyMax
Escape & Escape Hybrid
Jan 18, 2007 01:24 PM
