Replacing Mirrors
Old Dec 2, 2009 | 10:18 PM
wblukens's Avatar
wblukens
Replacing Mirrors
I have 99 Exped. Eddie Bauer with the power, heated, signal mirrors. They are faded so badly that they are unsafe. Can I replace with just power and heated, no signal? Signal mirrors prices are outrageous.
Old Dec 2, 2009 | 11:42 PM
minitrk's Avatar
minitrk
why cant you just replace the glass? would be the cheapest.
Old Dec 3, 2009 | 09:56 AM
dirtmonkey11's Avatar
dirtmonkey11
I have never done this but I assume that it could be done. You would just replace the mirror and not use the heated power wire. The only problem I would see doing this is if the turn signal light and the heated power wire are in the same connector, In that case I wouild try to take apart the connector and remove wire for the heated mirrors. Another option would be to remove the fuse for the heated mirrors that way you shouldn't have to remove the wire from the connector. Like I said I am not sure if any of what I said will work, just going off prior knowledge
Old Dec 3, 2009 | 12:02 PM
alwaysfords41's Avatar
alwaysfords41
There were TSB's for mirror delamination and fading back then, I had a pair replaced on my '99 under warranty. I believe it was just the glass.
Old Dec 3, 2009 | 09:39 PM
Icefan71's Avatar
Icefan71
At one time the Muth mirror company was replacing the mirror glass in Expeditions for free. I called them myself and they confirmed it. I believe you order a new set of mirror glass, and they charge your credit card. When you send back your damaged glass they remove the charge. I don't know the phone number, but I'm sure you can google it. Give it a shot.
Old Dec 3, 2009 | 10:39 PM
alloro's Avatar
alloro
Muth Mirror Systems, LLC - Contact Us
sprudo
Sep 12, 2014 02:09 PM
muelheim
Jun 9, 2014 01:28 PM
LYTEMUP
Dec 22, 2013 02:35 PM
2001expedition
Oct 25, 2013 02:42 PM
TOW4H2O
May 18, 2013 07:17 PM
