Motor mounts; Solid vs. Rubber
Old Nov 30, 2009 | 08:36 PM
benmoderow's Avatar
benmoderow
I'm almost done with my 2wd to 4wd conversion. Now the motor mounts. My original engine that I'm re-using is a 460. The 2wd mounts that are on the engine have the rubber center. My plan was to use the 4wd frame perches and get a set of 4wd motor mounts, but the mounts that I got on ebay are solid. So here's my question; Do I keep the 2wd mounts with the rubber and fab frame perches or buy a set from summit, or do I use the 4wd frame perches and solid motor mounts? The engine is stock and I don't plan on doing much to it or using the truck for severe off roading. Thanks for any responses.
Old Dec 1, 2009 | 03:02 PM
ell Header's Avatar
ell Header
I heard those solid steel motor mounts are crap and that they eventually mess up ur truck. I recommend you use L&L Products rubber motor mounts they only run about $125 and they have a pretty good warranty.
This is there website www.landlproducts.com
Old Dec 1, 2009 | 03:40 PM
dlburch's Avatar
dlburch
I ordered the trans dapt mounts from Amazon for $100, they qualified for free super saver shipping and got a $30 credit for opening an amazon credit card (which I will pay off within the 20 day grace period!)
Amazon.com: Trans-Dapt 4226 Engine Swap Motor Mount Kit: Automotive
Old Dec 3, 2009 | 02:06 PM
ell Header's Avatar
ell Header
I don't know I go by the saying that " You get what you buy" I rather spend my money on a quality product.
Old Dec 3, 2009 | 06:15 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Solid motor mounts introduce a lot of vibration into the daily routine, but with a stock or mild motor it shouldn't be too bad. The main thing is to still use a rubber mount for the transmission, especially if you happen to be using a C6.
Josh
Randy Obrien
Jul 22, 2014 02:35 AM
Randy Obrien
Jul 13, 2014 07:27 PM
havi
1966 - 1977 Early Broncos
Dec 28, 2011 09:09 AM
stuck in the 70s
Nov 13, 2011 09:19 AM
havi
Jun 7, 2010 09:41 AM
