Interchangable parts?
Old Dec 2, 2009 | 06:08 PM
SNSTER's Avatar
SNSTER
I found a 1978 F-350 2WD for sale kinda locally. supposed to only have 58XXX miles on it. has the 460 in it which I want. From the one pic I have seen the body looks in decently good condition. I currently have a 1977 F-250 4WD with the 400. what all can I rob from the 78 that will fit the 77?
Old Dec 2, 2009 | 06:11 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Any body parts. The motors will interchange with some exhaust and motor mount mods. The rearend from the 78 will bolt into your truck but will be to narrow if its a dually.
Old Dec 2, 2009 | 06:13 PM
SNSTER's Avatar
SNSTER
it is a single wheel rear axle sorry forgot to add that
Old Dec 2, 2009 | 06:16 PM
crazyredneckanyhow
Take a centerpin to centerpin measurement but all the f350 ive seen have the narrow rear frame like the truck you have.
Old Dec 2, 2009 | 06:30 PM
cjstang32's Avatar
cjstang32
Because the F-350 2wd has a 140" wb and 34" frame the bed will be different as well. To use the cab you'd have to cut out the floor over the trans. 2wd automatic trucks have a lower trans tunnel. Manual trans and all 4x4 have the higher bolt-in piece which would have to be used in your swap (no big deal, just different).
Old Dec 2, 2009 | 06:34 PM
crazyredneckanyhow
How is the WB different? The only longer WB F-350s are the supercamper special IIRC.
Old Dec 2, 2009 | 06:43 PM
cjstang32's Avatar
cjstang32
All 73-79 regular cab 2wd F-350s had a 140" wb regardless of whether they were SCS, CS, Trailer Specials, etc. Some further information, Ford dropped the Super from the Super Camper Special after 1976.
Old Dec 2, 2009 | 07:49 PM
joebane's Avatar
joebane
i have an 1978 140" wb f-350 do you know where i could find the race trac trim for the spare tire cover,thanks
Old Dec 3, 2009 | 08:57 AM
SNSTER's Avatar
SNSTER
so the bed on the 2wd is different versus the 4wd?
Old Dec 3, 2009 | 09:02 AM
mark a.'s Avatar
mark a.
Is your truck a '77 High Boy or a '77.5 Low Boy ? Big difference there.
Old Dec 3, 2009 | 09:03 AM
SNSTER's Avatar
SNSTER
How do you tell the difference?
Old Dec 3, 2009 | 10:13 AM
SNSTER's Avatar
SNSTER
ok after some research I have determined mine to be a low boy before it was lifted lol. the VIN# ends in Z12817
Old Dec 3, 2009 | 04:38 PM
SNSTER's Avatar
SNSTER
any other input?
Old Dec 3, 2009 | 06:52 PM
joebane's Avatar
joebane
yes-it,s is the same length but due to a longer wheel base the fender openings are further back, and there is a removeable panel on the passenger side where the spare tire is mounted
healinhand
65
Jun 29, 2024 12:59 PM
lance65
24
Nov 5, 2012 04:27 PM
51chris
Oct 14, 2011 12:32 AM
iceman320
Nov 23, 2010 10:51 PM
