Sponsored by: Real Truck
OT-2002 Ford Windstar
Old Nov 27, 2009 | 07:45 PM
eicht's Avatar
eicht
Hi Guys,
Cant find a Windstar forum so I thought I would see if you guys might be able to help. My Sister's Windstar will not start after sitting even for a short period of time. While doing some trouble shooting I found that the #4 relay in the in-cabin fuse panel is causing the problem. The battery voltage stays steady when it is removed, but as soon as it is installed the battery voltage drops rapidly. We have a Haynes manual which does not tell us what is connected to this relay. The only thing I can find that does not work with this relay out is the interior/dome lights. The battery and charging system have been checked within the last couple days and are supposedly good. I would appreciate any help you guys can give on this. I can be reached directly at eicht@yahoo.com
Tim
Old Nov 27, 2009 | 07:49 PM
superdutyduck's Avatar
superdutyduck
bad relay!
Old Nov 27, 2009 | 08:47 PM
eicht's Avatar
eicht
Originally Posted by superdutyduck
bad relay!
I switched that relay with the one next to it and it had no effect on the problem. (They were the same part number)
Old Nov 27, 2009 | 10:47 PM
redford's Avatar
redford
FTE Leadership Emeritus
Here is a link to the owners manual for the 2002 Windstar.
http://www.motorcraftservice.com/pub.../02winog2e.pdf
Relay 4 is called "Switched System Power Relay #3"
Relay 3 is called "Front Blower Motor Relay"
Relay 1 is called "Switched System Power Relay #4"
Doesn't make a lick of sense to me.
Old Nov 27, 2009 | 10:48 PM
superdutyduck
so 4 is three and 1 is four?
eicht
2009 - 2014 F150
Jul 21, 2014 09:36 PM
eicht
May 9, 2010 07:09 AM
eicht
Feb 16, 2009 10:35 PM
eicht
Oct 20, 2006 07:59 AM
eicht
Sep 29, 2006 08:28 AM
