Sponsored by: Auxito
Key Programming
Old Nov 24, 2009 | 03:41 PM
musickerns's Avatar
musickerns
Key Programming
I have a 2001 ford f-150 truck and I need to program a third additional key for a remote starter I'm installing. can someone tell me how to do this thanks.
Old Nov 24, 2009 | 06:14 PM
n5926g's Avatar
n5926g
I seem to reacll that there will need to be at least one "module" added to make this work.I have Bulldog remote start with keyless entry,and alarm that was given to me.After doing some research I elected not to use it in my 07 as it was going to be Way TOO MUCH HASSLE....The exact name of the module escapes me at present,but iin essence it bypasses your PATS system.Perhaps posting this question in the Audio portion of the forum will get better results.Concerning programming a third key in its own right,Providing you have TWO original keys its a pretty simple procedure...but to my understanding this is not what your looking for.
Old Nov 24, 2009 | 06:35 PM
guyina4x4's Avatar
guyina4x4
owner manual
for my 02 the instructions were right in the owners manual
Old Nov 25, 2009 | 12:52 AM
Mawk's Avatar
Mawk
For the PATS key on 98 and newer, you'll need two working keys (which it sounds like you have) so here are the instructions"
1. Insert and existing key into the ignition cylinder.
2. Turn the ignition cylinder ON (RUN) and back to OFF. Ignition should stay on for at least ONE SECOND.
3. Remove the existing key and, within TEN seconds, insert a second working key and turn it to ON (RUN) and the back OFF. Ignition must be in ON for at least ONE second, but no more than TEN seconds. Remove the key.
4. Insert the new key before TWENTY seconds have elapsed and turn it to ON (RUN). Leave it the ON position for at least ONE second and turn back to OFF.
5. The security light will light up for THREE seconds to indicate that the new key has been successfully programmed.
Old Nov 25, 2009 | 05:28 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
What happens when you are only given one key for the truck when you bought it?
LOL
Probably going to have to go to ford to get a second key programmed ehh?
Old Nov 25, 2009 | 06:05 AM
shorebird's Avatar
shorebird
Check with your local locksmiths to see if they can make and program a 2nd key for less than the dealer. There are lots of threads about this subject. Here is one of them; https://www.ford-trucks.com/forums/9...pare-keys.html
Old Nov 25, 2009 | 03:07 PM
Mawk's Avatar
Mawk
LOL
You'll need atleast two WORKING keys to program the third. You cannot program a second key with only one working. This is where you have to bend over and pay a dealership. I went through the same thing, and no companies around me could do it without activating the Passive Anti Theft System. I paid to have a second one programmed, and did the third myself to save some money. It's unfortunate, but that's how the cookie crumbles.
sne43
Transit Connect
Jul 8, 2019 02:22 PM
henryr
Apr 28, 2016 01:18 PM
snakedoc
13
Jan 17, 2014 08:16 PM
white Buffalo
40
Oct 18, 2011 11:38 AM
tfdhanna
1997 - 2003 F150
Jan 27, 2004 02:06 PM
