knife sharpening tips?
Old Nov 23, 2009 | 12:14 PM
Bdox's Avatar
Bdox
Originally Posted by jroehl
This is more about sharpening woodworking tools (chisels and plane blades), but the principles apply, and it's a good read:
The Master Woodbutcher's Scary Sharp(TM) Page
Jason
Jason, very entertaining. The method described is close to my own system but told in a much more enjoyable way.
A worth 5,000th post. Way to go hombre!
Old Nov 23, 2009 | 02:25 PM
bpounds's Avatar
bpounds
Lansky - Google it.
Old Nov 23, 2009 | 05:46 PM
jroehl's Avatar
jroehl
Number 5000 was in the Club, but it was a joke.
I've actually met the owner of The Woodbutcher's Shop, though it's been over 5 years since I've seen him. I belong to several woodworking groups online, and we do get together from time to time, though I haven't been to a gathering in some time, nor have I done much woodworking in recent years.
For kitchen knives, I just use a sharpener that has a set of carbide cutters in a vee, next to a set of ceramic honers in a vee. Just draw the knife through the carbide 4-5 times, then the ceramic 4-5 times. Skip the carbide if the knife isn't too beat up. Neither my wife nor I are professional chefs, so this is quick and works reasonably well. Once in a while, I will break out a sharpening jig I have with a T-clamp and stones set in plastic handles with extendable rods that feed through slots in the clamp to maintain angle. With that setup, I can get a knife razor sharp, though it takes a while because the stones are narrow, resulting in quite a few passes over each side of the blade.
Jason
Old Nov 23, 2009 | 08:09 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I use the sandpaper method and ultra fine waterstones on straight edges like chisel and plane irons.
Though my EDC Kershaw pocket knife is razor sharp it is still a compromise between a lasting edge and the sharpest I could possibly make it.
For a kitchen or butchering knife you typically would want a little 'tooth' and a broader included angle to better support the cutting edge.
It will keep it's edge longer, allow you to hack through cartilage and scrape bone.
I know the Lansky Professional Crock Stick I have gives you a 40* included angle and 50* on the microbevel.
It's great for these sort of knives.
Old Nov 23, 2009 | 09:29 PM
Ford_Six's Avatar
Ford_Six
I use a four sided diamond hone from Harbor Freight. It would be nice if it had an 800 side instead of 600, but I have been happy with it. The key is to take your time and keep your angle consistent. Do three or four strokes on one side, then three or four on the other, then hold the knife edge side up and sight along the sharp edge in bright light. If you don't see any light reflected, you're done. If there is a shiny spot, have at it again.
The only way to really learn is to practice, but the one key to remember is that your time is worthless. You don't get paid for how many knives you can sharpen in a given time, so just concentrate on the one.
Old Nov 24, 2009 | 05:23 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Anyone ever used a ceramic knife? Sharp as hell.
Tim
Old Nov 24, 2009 | 09:16 AM
bpounds's Avatar
bpounds
I have one of these: Tool Sharpening the Tormek Way - Tormek Grinding Machines
Use that for many wordworking tools. But I still like the Lansky for pocket and hunting knives. It really takes all the need for skill out of the process.
Old Nov 25, 2009 | 08:59 PM
stormyrider's Avatar
stormyrider
old boy that sharpens knives for a living around here uses a belt sander with 400 grit paper on it. just don't keep it on long enought to get the blade hot and watch the angle. should take a few minutes to do both sides allowing a cooling period between sides.
ford2go
21
Jul 7, 2012 12:58 PM
websthes
25
Aug 5, 2007 01:03 AM
Aftrmidnite
Feb 13, 2006 12:30 AM
thefonz#1
Jan 7, 2006 01:22 PM
triton_2002
May 11, 2005 12:47 PM
