power steering fluid
Old Nov 20, 2009 | 01:41 AM
xplorerboy's Avatar
xplorerboy
i want to flush my power steering fluid on my 01 sport trac...i just want to know if i can i use MERCON V ATF? and how many quarts ...any help?
Old Nov 20, 2009 | 08:33 AM
KhanTyranitar's Avatar
KhanTyranitar
Yes you can, it is a great fluid to use as PS. Disconnect the return line to flush the system. How many quarts depends on how long it takes to get the old fluid out.
Old Dec 6, 2009 | 03:28 AM
ukexplorer's Avatar
ukexplorer
the owners manual for my 99 Ex 4.0 SOHC says I should use F type fluid in the power steering. Yet all you guys use Mercon. What should I use?
Old Dec 6, 2009 | 07:48 PM
steve(ill)'s Avatar
steve(ill)
normally the factory fill for the power steering is what they are putting in the transmission that year. Power steering must needs a good quality light oil... any trans fluid will do.. THe transmission is specifically designed for a certain fluid, so dont mix type F, Mercon and MERCON V in it. That being said, MERCON is being phased out and MERCON V is the new standard and upgrade for most systems.
mattymax
Oct 16, 2016 04:15 PM
rblaine9000
6.4L Power Stroke Diesel
Nov 23, 2013 03:38 PM
abyars111
Apr 16, 2013 05:36 PM
wicat3
15
Sep 24, 2012 06:20 PM
MJW
Mar 26, 2004 10:17 AM
