power steering fluid change
Old Mar 25, 2004 | 09:42 AM
MJW's Avatar
MJW
Question power steering fluid change
I want to replace the power steering fluid in my '02 with fresh fluid. Is there a procedure for this to remove all the fluid? Thanks.
Old Mar 26, 2004 | 07:30 AM
mueckster's Avatar
mueckster
You can suck the fluid from the P/S reservoir with a syringe, refill with fresh fluid, run it (working the steering side to side and pressing the brake), then repeat the process. There isn't that much fluid in the steering box or hydraboost, so flushing it will remove the majority of the old fluid.
Old Mar 26, 2004 | 10:17 AM
Birken Vogt's Avatar
Birken Vogt
In an 02 I wouldn't worry about a complete flush, but when I wanted to on an old truck what I did was to empty the reservoir, and disconnect both hoses from the pump. I then turned the engine with the starter until all the oil was out of the pump. Then I hooked shop air into the high pressure hose and directed the low pressure into the drain pan, and turned the wheel back and forth to empty the steering gear. Then refill and bleed the gear again by turning it back and forth with oil and the engine running. Probably a waste of time for you though, I just suck out what is in the reservoir now and refill yearly or so.
Birken
mattymax
Oct 16, 2016 04:15 PM
Vinford
May 7, 2014 05:56 AM
wicat3
15
Sep 24, 2012 06:20 PM
AGGIE68
1997 - 2003 F150
Jun 17, 2011 10:15 AM
SDJERSEY
Aug 7, 2004 07:52 AM
