volare steering box
Old Nov 8, 2009 | 04:15 PM
sid318's Avatar
sid318
volare steering box
Hi guys , anybody know why my steering flys to the right when i let go of steering wheel ? ie when running , have volare clip on my f100 54, cheers any help much appreciated, foreverford kev, uk.
Old Nov 8, 2009 | 04:43 PM
raerjim's Avatar
raerjim
More than likely a tire issue, Kev. Try swapping the fronts, left to right, right to left, and see what that does. I'll bet it pulls to the left. Let us know.
Old Nov 8, 2009 | 05:20 PM
Old F1's Avatar
Old F1
Is this while driving on the road or sitting still? (not as dumb as questions as you might think, hook up the hoses wrong on a MII and you’ll see, watch out for your hand).
Maybe is because the Volare part doesn’t know that it is in the united kingdom and wants to get onto the correct side of the road?
Old Nov 8, 2009 | 05:52 PM
larryb346's Avatar
larryb346
Sid318
If your talking about when the front end is off the ground and the steering wheel turns when you start the engine, the chy. steering boxes had to be "centered".
If while wheels are on the road and driving can be brakes dragging on one side, wheel bearing bad on one side, front end alignment way off, low tire, bad tire, and the list can go on and on.
Old Nov 8, 2009 | 06:51 PM
fatfenders's Avatar
fatfenders
alignment is my bet.
Old Nov 9, 2009 | 07:51 AM
sid318's Avatar
sid318
cheers guys
never thought of allignment , ddoo ! not had truck alligned yet as still finishing build, all new parts on front end inc w/tires, so most likely problem, liked the right hand side driving joke , cheers guys,
Old Nov 9, 2009 | 06:01 PM
Dr G's Avatar
Dr G
Almost anytime I've had a car pull left or right when driving it has been due to a camber imbalance. Though a caster imbalance would also induce this.
Gustave
Old Nov 9, 2009 | 06:03 PM
Dr G's Avatar
Dr G
Just noticed you've done a full rebuild? You would want to check for square, that the rear axle is pointed straight ahead and not skewed, or translated off-center.
That will make the vehicle "crab" down the road and will feel like a pull to the driver.
Gustave
Old Nov 9, 2009 | 10:53 PM
Last Chance 56's Avatar
Last Chance 56
Could have it lower to much. I did that and about got a DUI, sober. Do not need any comments from the ones that know me, I was sober.
Last Chance 56
I think that I was.
mr56effie
Jul 25, 2014 07:18 PM
arts48
Jul 23, 2014 03:00 PM
675080
Oct 4, 2007 09:42 AM
poolpro51
Jan 19, 2005 06:03 PM
edsf100
Oct 31, 2004 12:47 PM
