codes?????
Old Nov 10, 2009 | 05:43 PM
lennb01's Avatar
lennb01
the truck runs really rich and you punch the gas it just bogs and stall if you dont let go of the gas
Old Nov 10, 2009 | 05:44 PM
lennb01's Avatar
lennb01
got any advice subford?????????????
Old Nov 10, 2009 | 05:58 PM
subford's Avatar
subford
Make sure the small black wire with a green stripe has a good connection to the NEG (-) post of the battery.
Make sure the NEG battery cable has a good connection to the engine block (not the frame).
Make sure there is a good ground from the NEG post of the battery to the body with a #10 or larger wire (stock is a black wire with a white stripe).
Check the ground from the engine to the firewall.
cttbax
Nov 21, 2012 10:19 AM
traxx808
May 2, 2011 09:13 AM
drivembig
Jan 13, 2010 06:49 PM
ozzy460
Jan 6, 2008 05:56 PM
quisp-n-quake
Jan 21, 2006 06:03 PM
