codes?????
Old Nov 8, 2009 | 06:34 AM
lennb01's Avatar
lennb01
codes?????
last week i asked about not being able to get codes out my 88 f150 4.9 with a cheap code scanner ,well i took it to a garage and the guy couldn't get them either.start the truck up and his scanner would come on but with the truck off and key on scanner has no power .anyone have any ideas what could happening. we checked the plug with a light tester nothing and then a volt meter still nothing.thanks in advance for the info
Old Nov 8, 2009 | 08:02 AM
subford's Avatar
subford
You do not have a power source at the EEC Self-Test Connector (plug).
The guy at the garage does not know your system.
Are you grounding the STI wire or plugging it into the scanner?
Old Nov 8, 2009 | 10:20 AM
lennb01's Avatar
lennb01
he has a snap-on code scanner and both plugs were plugged in
Old Nov 8, 2009 | 10:22 AM
lennb01's Avatar
lennb01
theres power when the truck is running but not when its not w/key in on position
Old Nov 8, 2009 | 10:27 AM
rla2005's Avatar
rla2005
This might help: Ford Fuel Injection No Codes?
Old Nov 8, 2009 | 10:31 AM
lennb01's Avatar
lennb01
we checked everything on that list more than once but ty anyway
Old Nov 8, 2009 | 12:56 PM
brett12396f150's Avatar
brett12396f150
Did you take the power cord and plug it into the part that plugs onto your truck to ground it?
Old Nov 8, 2009 | 07:09 PM
subford's Avatar
subford
What wire has power on with the engine running?
One of the wires that could have power is the Fuel Pump Coil to pin # 22 of the computer and if it has power the fuel pumps are not running. So how is the engine running with no fuel?
If it does not have power with the key on and the engine not running then the EEC Power relay is not closed or the fuel pumps are running with the engine off. That would mean a bad Power Relay, Ignition Switch or no ground on the small black wire with a green stripe at the NEG (-) post of the battery.
We will not address the part that the fuel pumps are running with the engine not running at this point.
In other words what you are saying can not happen with power at pin #6 of that plug.
The other wire that may read power sometimes is the CEL wire. It has power with the light off and no power with the CEL on.
There should not be any power on that plug with the engine running and there should be power with engine not running with the key on.
It would have power with it running as the CEL should be off and no power on it with the engine off and key on with the with the CEL on.
The last wire is a ground wire and it has no power at any time.
So as I said above there is no wire there that is a power source.
Old Nov 9, 2009 | 05:56 AM
lennb01's Avatar
lennb01
i cheked the wires with a test light 1 wire has power ,1 is heater fan,1 has nothing and 1 is fuel pump
Old Nov 9, 2009 | 06:37 AM
subford's Avatar
subford
"1 is heater fan"????????
There is no heater wires in the EEC Self-Test PLug.
What plug are you playing with?
Old Nov 9, 2009 | 04:22 PM
lennb01's Avatar
lennb01
with the truck off and key on touch the top wire (sig ret) with test light and the heater fan goes on
Old Nov 10, 2009 | 06:48 AM
subford's Avatar
subford
SIG RET is a ground wire for the 5 volt sensors but also goes to ground after going through the computer.
It sounds like you are on the wrong plug. The plug you are trying to test with is the resister plug on the heater box for the fan speeds.
Take a look at this URL:
http://fordfuelinjection.com/?p=13
SIG RET or J1-46 SIG GND in the diagram below:
Old Nov 10, 2009 | 05:26 PM
lennb01's Avatar
lennb01
thats the plug that i am plugged into its on the driver side fender wall
Old Nov 10, 2009 | 05:29 PM
subford's Avatar
subford
If you stick a test light into a ground wire and the heater fan comes on you must have a lot of ground problems.
Old Nov 10, 2009 | 05:36 PM
lennb01's Avatar
lennb01
maybe thats why the delay wipers dont work and the gas gauges work wierd
