1993 f150
Old Nov 10, 2009 | 07:08 PM
jason85351's Avatar
jason85351
1993 f150
So heres my new truck traded my 85 f150 for it. its got a 351w C6 b+m shifter,np208 TC, 7 inch lift. so now the problems the transfer case was bad so i took the 4 wheel drive shaft out (cause it has auto hubs) to save it for a bit. so i changed the TC and put the driveshaft back in and it still makes the same rattleing noise as before when im doing any speed over 30mph. when i take the shaft out its fine again i checked the u-joints there fine most of them new.. im stuck with this noise its annoying also i want to put 37's on this truck do you think if i did a SAS and put a dana 44 solid axle in the front and geared the truck to 410's it would hold up i dont beat on it but will do some slow wheeling Thanks
Old Nov 10, 2009 | 07:24 PM
rla2005's Avatar
rla2005
Sounds to me like a drive shaft problem. My '92 F350 uses a double Cardan joint similar to a constant velocity joint used on FWD vehicles. There is a fulcrum like plate with a bearing in it that went bad. Mine had a squeaking noise. Not sure if your F150 uses the same setup. But I would take a good look at your DS before going to all the trouble of a SAS.
Old Nov 10, 2009 | 07:32 PM
jason85351's Avatar
jason85351
i do have a spare Driveshaft that i just took out of an 85 f150 ill bolt it in this weekend and see what happens Thanks
Old Nov 10, 2009 | 07:46 PM
rla2005's Avatar
rla2005
The splines of the slip joint on the DS are known to go dry over time. It might be worthwhile to pull it apart and apply some grease too.
npd23
18
Mar 24, 2021 08:18 PM
Nally427
21
Nov 2, 2020 04:43 PM
strokin'_tatsch
603
Dec 7, 2012 02:26 AM
taxreliever77
Sep 12, 2010 02:14 PM
ekbearly
Jul 23, 2010 06:50 PM
