Cat delete ordered
Old Sep 24, 2012 | 11:03 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I bought the one posted. Didn't need any new bolts. Drove the OEM ones out. They are just pressed in.
Old Sep 24, 2012 | 05:27 PM
Bruin008's Avatar
Bruin008
Got ya. Ill have to look at it the time comes. I gotta do a coolant flush oil change n fuel filter change yet. Little more important then deleting the cat. I just did the blue spring updaye n cleaned my egr vlave today.
Old Sep 28, 2012 | 04:05 AM
Bruin008's Avatar
Bruin008
can you post pics of your install. im curious to see how it looks. im assuming you use clamps.
Old Sep 28, 2012 | 07:48 AM
MisterCMK's Avatar
MisterCMK
Originally Posted by rsmarcil
From that link posted above. PureDieselPower.com All you will need is the two extra bolts w/nuts as stated in one of the posts. This is for the stock piping only which is 3 1/2".
When I ordered the delete from PureDieselPower it came with the bolts.
Old Sep 28, 2012 | 07:49 AM
MisterCMK's Avatar
MisterCMK
The factory clamp works on the back side. The front is a flange.
Old Sep 28, 2012 | 10:44 AM
amdriven2liv
It just bolts right in. Notice the collar on the one end? It bolts right to the stock exhaust collar on my 04. 2 bolts at the collar and one on the stock clamp on the other end. Wiggle it some, and the cat pops out. You need to disconnect the hanger near the front for easier removal. Takes me longer to get the tools out than to remove the pipe.!
KEEP YOUR CAT!!!!!!!!!!!!!!!!!!!!! You never know when you might need it.
03-07+ Ford 6.0L Powerstroke Diesel Cat Delete Pipe
tcjhkbjt
Sep 25, 2014 10:20 PM
mudmagnet63
6.4L Power Stroke Diesel
Apr 29, 2014 08:42 PM
97biostroke
Nov 27, 2012 10:44 PM
elkarcher
Sep 18, 2007 03:17 PM
wc46
Nov 29, 2006 08:28 AM
