flush rear bumper
My 79 F250 didn't have a bumper when I bought it. The flush (non-step oem) is called the contour bumper. I bought one from Jeff's Bronco Graveyard. LMC sells some as well in addition to aftermarket step bumpers. There are two sizes; F350s have frames 33 inches apart. Everything else has 37 inch frame width. For the truck you mentioned, the wider one is what you want. The bumper brackets will be harder to find. You can mess around with fabricating your own from 1/4" plate. I bought brackets from blue oval truck parts. Overpriced but the right fit. The brackets have a weird shape. Recommend Bronco Graveyard or you could try one of this site sponsors.
Rear bumper components from Bronco Graveyard
http://broncograveyard.com/bronco/c-132-stock-rear.html
But I re-read your post. Sounds like you talked about a roll pan as mentioned above. LMC roll pans:
http://www.lmctruck.com/icatalog/fc/full.aspx?Page=75
I know you have to paint them. They aren't my thing so I haven't researched them anymore than that.
Rear bumper components from Bronco Graveyard http://broncograveyard.com/bronco/c-132-stock-rear.html But I re-read your post. Sounds like you talked about a roll pan as mentioned above. LMC roll pans: http://www.lmctruck.com/icatalog/fc/full.aspx?Page=75 I know you have to paint them. They aren't my thing so I haven't researched them anymore than that.
pat2345
02-23-2009 05:34 AM
72XLT
09-16-2006 11:51 AM
