Hey guys this is my first post on here. I've been searching for a 76-79 short box 4x4 and I found one that had a flush rear bumper on it. The truck was to spendy but I would like to put one on the truck I buy. Any place I can find one of these?
My 79 F250 didn't have a bumper when I bought it. The flush (non-step oem) is called the contour bumper. I bought one from Jeff's Bronco Graveyard. LMC sells some as well in addition to aftermarket step bumpers. There are two sizes; F350s have frames 33 inches apart. Everything else has 37 inch frame width. For the truck you mentioned, the wider one is what you want. The bumper brackets will be harder to find. You can mess around with fabricating your own from 1/4" plate. I bought brackets from blue oval truck parts. Overpriced but the right fit. The brackets have a weird shape. Recommend Bronco Graveyard or you could try one of this site sponsors.
