Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
f600 ebrake help
Old Oct 27, 2009 | 03:12 AM
woodslip's Avatar
woodslip
f600 ebrake help
hellow
i need help in fixing my ebrake........its on the driveshaft.......adjusted as much as possible......
where can i buy pads for this.....and does anyone have instructions
on how to do it.........
thanks keith
Old Oct 27, 2009 | 06:39 AM
86f350's Avatar
86f350
I dont know where to buy them but you can order a repair manual off ebay (only place i know of) to show you how.
For now i think your gonna be needing a good set of chalks. : )
Old Oct 27, 2009 | 07:34 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
What do the current shoes look like? Is there material on them? Or are they worn/broken off? Usually a "parking" brake doesn't see any wear so they shouldn't be worn. Unless they got gear lube on them
What year is the truck?
I know a local place here on Long Island that would probably be able to get them, or know where to go...
Did you try NAPA?
Old Oct 27, 2009 | 07:35 PM
woodslip's Avatar
woodslip
i have not look at them......for i dont really know how to take them apart........my truck is down right now.....busted leaf spring........when i get it home i will take a good look at
them to see if gear lube is on them.......thanks again
Old Oct 28, 2009 | 05:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
As Krewat said, you should be able to get the parking brake drum brakes shoes from NAPA.
Ford used this parking brake setup on big trucks for decades.
But...there are different sizes. The shoes could be 9" x 2" or 9" x 3" or? If I knew what year you have...I could prolly tell you.
PLEASE...when asking questions, list ALL the pertinent details.
The year, and the GVW...which on BIG trucks is very important when it comes to brake parts.
The GVW is found on the Warranty Plate thru 1980, on the Certification Label 1981 and later.
JOB LOT specializes in BIG Ford truck parts, is located in Queens NY (joblotauto.com). But like us here on FTE, they need to know the pertinent details before they can help you.
SHOP MANUALS: Depending on what year you have, original new genuine Ford manuals are available from helminc.com from the 1980's and later.
Prior to the 1980's, faxonautolit.com has used shop manuals and/or reprints of these manuals.
Old Oct 28, 2009 | 08:05 AM
jpr38057's Avatar
jpr38057
If NAPA doesn't have them and you live in a somewhat large city there is probably some place in town that can reline the shoes you have. Call around to some of the places that carry truck parts.
Old Oct 28, 2009 | 02:07 PM
NumberDummy
Ford dealers carry new shoes w/lining, and/or relined shoes. These come in a kit.
I have the in-house Ford Dealer Parts Locator System, which means I can list every FoMoCo Dealer in the US that carries these shoes (and every other car/truck part you can name).
But...without knowing the year of the truck, and what size the brake shoes are, I'm not typing dozens of Ford Dealers for each brake shoe kit part number.
Old Oct 28, 2009 | 06:04 PM
woodslip's Avatar
woodslip
thanks numbers.......its a 1978 dump truck........i just picked up the u bolts for the rear leaf springs today.....hope to have it running by tomorrow.......thanks i can give you the
size of the ebrake pads or shoes.....which ever they are.....thanks again
keith
barryjdi
Mar 18, 2015 11:10 PM
lamenytro
Jul 19, 2013 03:01 PM
Visseroth
May 23, 2010 04:15 PM
gd2227
1997 - 2003 F150
Mar 3, 2010 09:22 PM
saint99
1983 - 2012 Ranger & B-Series
22
Dec 13, 2008 10:40 AM
