e-brake repairs thread?
Old May 22, 2010 | 05:12 PM
Visseroth's Avatar
Visseroth
OK, so I've been searching around and I can't seem to find it, forgive me, but does anyone have a link or a how to on doing e-brake repairs, how to tighten the e-brake, something like that. I and another guy need to do some e-brake work.
Old May 22, 2010 | 06:33 PM
clintbonnie's Avatar
clintbonnie
Found this on the internet...
How do you adjust the parking brake of a 2001 f350?
In: Ford F-350 [Edit categories]
Parking Brake Repair
Answer
First make sure the service brakes are adjusted properly
Adjustment will either be at the junction of the 3 cables under the vehicle or at the pedal itself
Set pedal at 3 clicks and the wheels should be locked at that point ...
I would guess if your e brake is not holding, you probably need new e brake pads.. Remove rear rotors to replace pads if needed if the adjustment mentioned above does not cure the problem..
Old May 22, 2010 | 08:37 PM
camodown's Avatar
camodown
There is a star adjuster that you can use a flat blade screwdriver to turn, kind of like the adjusters used for drum brakes in the 'old days'. The longer you make the assembly, the closer the shoes are put towards the inner part of the rotor. Check to see if your wheels seals have leaked grease onto the shoes also. If you adjust it too much, you will break the cable...
Old May 22, 2010 | 08:39 PM
camodown's Avatar
camodown
There is an 'access' rubber gromett on the bottom of the dust shield area. Pop the gromett out and use a flat blade to turn the star wheel adjuster. If you want pics let me know!
Old May 22, 2010 | 09:17 PM
Visseroth's Avatar
Visseroth
Yea, that would be great. I take it that this grommet is on the back of the wheel?
Old May 22, 2010 | 11:51 PM
camodown's Avatar
camodown
Sorry it took so long. See below
There you can see what you are adjusting
There is the gromett.
The access hole is between the two nuts/studs which hold the bracket to the axle. Right in front of the caliper.
Make sure you don't have your e brake engaged when adjusting and use chocks.
Old May 23, 2010 | 12:48 AM
Visseroth's Avatar
Visseroth
huh, no self adjusters? Well that sucks. Looks pretty easy to rebuild though.
Old May 23, 2010 | 05:06 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
That'd be sad there's no self adjustment. IIRC my '66 Mustang had a self-adjusting parking brake.
Old May 23, 2010 | 10:15 AM
SpringerPop's Avatar
SpringerPop
There really shouldn't be a need for self-adjusters to "keep them adjusted", as they should never wear enough to need it.
Unless you forget they are applied and drive on them, there's no material ever removed.
They are applied, or they are free. Shouldn't be much "in between".
Even the older drum brakes, that incorporated the park brake into the service brakes, needed an initial manual adjustment.
Pop
Old May 23, 2010 | 04:15 PM
Visseroth's Avatar
Visseroth
Not completely true. My wife's van has drums on the back and you just simply put them in loose, start the van and start pumping, they will automatically adjust.
rblaine1004
Apr 23, 2016 11:07 AM
taz6131965
Nov 30, 2015 01:23 PM
02GrayPowerStroke
1997 - 2003 F150
23
Jul 25, 2015 09:11 PM
66F250CS
Dec 29, 2014 11:24 PM
hasbeen
Sep 19, 2003 08:54 AM
