AIH delete?
Old Oct 17, 2009 | 01:29 PM
74baja's Avatar
74baja
AIH delete?
Hi all,
I've been thinking about the AIH delete. Is it worth it? I hate how sluggish the truck is when it's cold, so will deleting the AIH make the engine take much longer to warm up? Are the benefits noticeable?
Thanks
Old Oct 17, 2009 | 01:35 PM
Izzy351's Avatar
Izzy351
It's more aesthetic that anything else. Yeah, it takes a big chunk of metal out or the intake path, but I doubt it's something you'll be able to tell. And the AIH only kicks on when you're parked and idling for a while when it's cold enough. It doesn't come on when you're driving or anything, so it doesn't do anything for warm-up. Just helps with white smoke in cold weather. No biggie.
Old Oct 17, 2009 | 02:08 PM
binuya's Avatar
binuya
I used the port to install one of Clay's cool delete plugs, and intalled an Isspro electronic boost sensor there. Very responsive boost gauge, and I personally, preferred not to have to run more air line.
Old Oct 17, 2009 | 02:45 PM
gasgrunt88's Avatar
gasgrunt88
The way Clay explained it to me there are like 7 things that have to be happening in order for the AIH to be on/operating. Problem is, there are rarely more than like 5 of those processes happening so it is almost pointless to keep the AIH in there.
Old Oct 17, 2009 | 03:46 PM
Justin03PSD's Avatar
Justin03PSD
+1 for Clay's plug, especially if you need a port for a boost gauge.
Old Oct 17, 2009 | 07:02 PM
big poppa's Avatar
big poppa
No problems here, Joe explained it pretty good. Here's the heater element removed and Clay's AIH tapped delete plug with boost fitting, a clean install.
Old Oct 17, 2009 | 07:14 PM
Mike F250's Avatar
Mike F250
hmm, extend the AIH wires inside the cab and use that to heat my coffee when I get back from my tree stand
Old Oct 17, 2009 | 07:28 PM
big poppa's Avatar
big poppa
Hum, I think you might have something there.
Old Oct 17, 2009 | 07:46 PM
maevans's Avatar
maevans
I like the way you think.
Old Oct 17, 2009 | 10:07 PM
binuya's Avatar
binuya
..................nice.
Old Oct 19, 2009 | 11:22 AM
njellison's Avatar
njellison
So it sounds like it might provide some help pre-heating the air when we start our trucks on cold mornings. if there was a way to program it to stay on for the intitial warm up I wonder if it would make a difference and speed up our warm up time. There is a performance loss when air is warmer vs colder due to loss of air density but might be worth the trade off during warm up as I try not to run it hard until its warm anyway.
Is it worth it or is the amount of heating not sufficient or significant at flow speeds of 1700 rpm or so?
Old Oct 19, 2009 | 11:25 AM
Izzy351's Avatar
Izzy351
I don't think so. That's why the GPs stay on for up to several minutes depending how cold it is. The AIH is specifically for limiting white smoke when cold.
Old Oct 30, 2009 | 11:49 PM
flatbeder's Avatar
flatbeder
when i buy the AIH delete with theard can i put a threaded plug in the hole for the gauge? plan on gauges in the near future...
Old Oct 30, 2009 | 11:50 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Yep, its just 1/8" NPT.
Old Oct 30, 2009 | 11:53 PM
flatbeder's Avatar
flatbeder
thanks agian Clay
bobiker
Aug 21, 2013 03:06 PM
F-250 Super Duty
29
Apr 5, 2013 07:09 AM
Jessef250
Jan 9, 2011 05:06 PM
mybigredford
30
Jun 2, 2010 12:30 PM
renyren
17
Nov 19, 2009 09:34 AM
