ac clutch grinding
Old Oct 30, 2009 | 06:12 PM
LaJ10's Avatar
LaJ10
ac clutch grinding
I am having a problem.It is a grinding noise that I think is the ac clutch.I thought I had remebered someone talking about "shimming"it but can't seem to find it.Is it possible?
Old Oct 30, 2009 | 08:11 PM
rbaker6336's Avatar
rbaker6336
Does it do it with the A/c both on and off
Old Oct 30, 2009 | 08:13 PM
tbone heller's Avatar
tbone heller
If you shim it too much, the clutch won't engage.
Remove the bolt at the end of the compressor,& remove the clutch "shoe". The shim is a shall thin washer that fits between the "shoe" & the compressor shaft.
HINT: A little dab of grease will hold the shim in place while putting it back together, & NO, the belt does not need to come off.
Old Oct 30, 2009 | 08:17 PM
LaJ10's Avatar
LaJ10
Yes it does it with the clutch engauged or without it engauged.At first I thought it was one of the idler pully or tensioner pullies but changed them all with no luck.I can spray pb blaster in the back side of the clutch and it will quite down for a few seconds.
SpringerPop's Avatar
SpringerPop
Here's a test:
https://www.ford-trucks.com/forums/5...ml#post4464164
But it may be your compressor's input shaft bearing, too.
Pop
Old Oct 30, 2009 | 08:20 PM
rbaker6336's Avatar
rbaker6336
sounds like the bearing may be giving up,which if is the case is not good with one belt
Old Oct 30, 2009 | 08:24 PM
LaJ10's Avatar
LaJ10
That was my thought also .Does a new clutch come with a new bearing?If not can the bearing be changed with everything on the truck and will the freon be lost?
Old Oct 30, 2009 | 08:29 PM
LaJ10's Avatar
LaJ10
The thread referred to above does not sound like my problem .My clutch seems to engauge fine it just makes quit a bit of noise
Old Oct 30, 2009 | 08:32 PM
rbaker6336's Avatar
rbaker6336
To be honest I don't remember,maybe someone will come along that has worked on one recently
Old Oct 30, 2009 | 08:38 PM
LaJ10's Avatar
LaJ10
My local autozone has the clutch in stock so I'm good there I just am not sure of the bearing .Is it mounted in the clutch itself or in the compressor?
Old Oct 31, 2009 | 01:42 AM
SpringerPop
If you need to replace the entire compressor, you need to reclaim the refrigerant (legally, anyway), then get the refrigerant o-rings that seal the connections.
Then, you need to find out how much oil you are removing from the system with the old compressor, and add it back to maintain the correct amount. This might be also a good time to consider a new accumulator/filter/dryer assembly (and those o-rings, too).
Then, you really SHOULD get a set of gauges and at least borrow a vacuum pump sufficient to pull a deep vacuum for at least an hour. Then, you need to determine if you can maintain that vacuum (any leaks in the sealed system?), and only THEN do you re-charge the system with the prescribed amount of refrigerant R-134a.
Whew!
But...., you CAN do this yourself, and save a bunch-o-bux!
Pop
Old Oct 31, 2009 | 08:01 AM
LaJ10's Avatar
LaJ10
Not what I wanted to her but thanks SP.I can do all the ac stuff,but hate the cost of it all.
leforrest
1997 - 2003 F150
Sep 25, 2013 03:05 PM
mojo79
Nov 2, 2010 09:08 PM
berry1234
May 20, 2010 09:40 AM
skilife17
1997 - 2003 F150
Jun 25, 2007 08:56 PM
turdbird
Dec 13, 2006 05:33 PM
