truck pulling to one side
Old Oct 13, 2009 | 10:10 AM
kupaa's Avatar
kupaa
I was playing around last week and did a 4 wheel boosted launch now it pulls to the right alot.Installed a leveling kit about 4months ago but everything looks good under the front end.What should i check,how do i aligned the front tires?
Old Oct 13, 2009 | 11:14 AM
just another truck's Avatar
just another truck
when you hit the brakes, does it pull the other way?
Old Oct 13, 2009 | 11:31 AM
mechelement's Avatar
mechelement
Mine pulled to the left when my caliper pin seized on the driver's side. Did you get some wheel hop during your launch? A washboard dirt road caused my caliper pin to seize. I performed the upgrade to both sides and haven't had any issues since. Have you checked your ball joints and steering joints? To get an alignment, go into a reputable tire shop and have them perform one.
Old Oct 13, 2009 | 12:20 PM
brian42's Avatar
brian42
Veteran: Navy
Just as a dummy check...have you made sure your track bar is working okay?
Old Oct 14, 2009 | 10:32 AM
kupaa's Avatar
kupaa
How do i know if my track bar is working or not?
Old Oct 14, 2009 | 10:34 AM
kupaa's Avatar
kupaa
It pulls the same way when i hit the brakes
Old Oct 14, 2009 | 10:39 AM
just another truck
Have you verified your hubs are unlocked?
Old Oct 14, 2009 | 11:25 AM
mechelement
Have you performed the caliper pin upgrade? If not, whatever side you're pulling to while driving and braking could have a seized pin. Mine pulled to the left while driving and even harder in that same direction while braking.
Old Oct 14, 2009 | 12:06 PM
kupaa's Avatar
kupaa
Yep it's unlocked
Old Oct 14, 2009 | 12:11 PM
kupaa's Avatar
kupaa
[QUOTE=mechelement;8033918]Have you performed the caliper pin upgrade? If not, whatever side you're pulling to while driving and braking could have a seized pin. Mine pulled to the left while driving and even harder in that same direction while braking.[/QUOTE
I changed all the brakes six months ago and lubes all the caliper pin but how would that make it pull from a 4wheel lounch
Old Oct 14, 2009 | 12:34 PM
BeBo03's Avatar
BeBo03
Seizd pin location
I guess I'm a little slow where is this "seized pin" located? I did a brake job 1 year ago and it has been pulling to the left (driver side). I also noticed there is more brake dust on the driver side than the passenger side. I thought the passenger brake line got damaged so I replaced it and bled the line. Any input would be great. Thanks!
Old Oct 14, 2009 | 02:20 PM
mechelement
I think vibrations cause the caliper pins to stick due to the stock design. Ford came out with a new design w/ a rubber grommet on two of the four pins which is better for vibrations I guess.
Maybe coincidentally the pin seized during your launch. Did you notice any wheel hop? Were you offroad or on a dirt road that was bumpy?
I did a brake job, including lubing the stock caliper slide pins, 7 months before my caliper pin seized on a dirt road. One big bump seized it. I noticed it had been sticking a bit because of the slight pull to the left and more so during braking. When it seized, there was a loud screeching while braking and it pulled wildly out of control. So yours could just be sticking. Did you bend a spring, shackle or part of your suspension?
Old Oct 14, 2009 | 05:28 PM
brian42's Avatar
brian42
Veteran: Navy
It's a bar that mounts on the axle and the frame to make sure that the axle stays centered under the truck. If either mount is off or loose, the axle could "walk" to one side under a hard launch with the front driving too.
Old Oct 14, 2009 | 08:19 PM
aldridgec's Avatar
aldridgec
In addition i would make sure you didn't shift a spring up front. If during the launch, if it was hard enough, can put lateral stress on the springs through the track bar. This can shift the front end and cause the truck to "pull".
Is it actually pulling, or is the wheel off center?
Likewise the same thing could happen in the rear, and that would cause the truck to constantly push to one side.
Measure your wheel base accurately. This will tell you if anything shifted. An alignment check won't necessarily show that kind of problem.
chawhee
Jul 28, 2013 08:48 PM
86capriASC
1997 - 2003 F150
Jul 8, 2012 08:40 PM
351Cleveland C4
1983 - 2012 Ranger & B-Series
Oct 9, 2011 10:12 PM
blloyd
Feb 22, 2008 07:07 PM
Regta
1997 - 2003 F150
Dec 10, 2006 08:53 AM
