5.4 needs to come out of the '99
You'll only need to remove the fan and radiator and there will just be enough room to pull it out once you disconnect it from the torque converter. I also removed the intake manifold, gives you more room and easy places to bolt on the chains front and back. Also lets you get to the top tranny bolts fairly easily. Only place you really need to people is when the engine comes out and you are about an inch away from the front coolers/condenser and the back wiper cowl. I put a double layer of cardboard taped to the condenser and it definitely saved it from some bolts that came in contact.
Old man 23
06-06-2015 09:16 PM
