I getting ready to replace the stock spark plugs on my '02 F-150 with the 5.4L. The owners manual calls for Motorcraft AGSF-22W. The only place I've been able to find these plugs is at the dealer for $8.49 each . Can anyone tell me what the equivilant Autolite plugs would be? I've been told by several people to only use Motorcraft or Autolite plugs. Thanks!
Platinum.
Motorcraft SP-479 @ autozone for about $3.50 each or Autolite APP103. About $4 @ autozone.
I used the sp-479 in my 01 5.4L with no problems. These newer plugs have more threads than the original, but work the same.
Personally I would stick to the OEM plugs...granted theyre not cheap,but this will likely be the last plug change youll do on the truck.....make her happy,and give her the OEM stuff!
I tried the iridium and pulled them out after @500 miles and installed Autolite double plats. Longer starts was one of the problems with the iridiums. That was $100 wasted plus the time and effort to change the plugs twice.
Platinum.
I use the Motorcraft SP-479. They're Motorcraft OEM equivalent, have the Motorcraft part number on them, and they're $3.49 each at my local Autozone.
You will be happy with those. The iridiums would work well too, but they would offer no real world benefits. The iridium lasts longer, but that doesn't stop them from gradually fouling out. So you would end up replacing them at the same interval as a platinum plug anyway.
I'm not sure I understand what you are saying. When plugs wear out they do not "gradually foul out". The electrodes wear, the gap increases but fouling out isn't what happens. If your plugs are fouled on a modern fuel injected engine, you have much bigger issues than worn plugs.
Well, I changed the plugs tonight. It took about an hour and fifteen minutes and wasn't really that difficult. The hardest part was finding the right combination of swivels and extensions to make it work. Turns out the factory plugs had already been replaced at some point, but I put the new ones in anyway.
Iridium plugs can last so long, and they tend to give a sense of security. The chances of leaving those plugs in there for 200,000 miles or more without something going wrong in the fuel management is almost non-existent. The plugs are outlasting several set of O2 sensors To me it just seems redundant to use a plug, which is a maintenance item, that outlasts other maintenance items by such an enormous amount of time.
