spark plugs
Old Jan 30, 2014 | 01:08 PM
1999stroke's Avatar
1999stroke
spark plugs
hey guys been wondering was at my local oreilly's the other day and saw that they had motorcraft platinum plugs available in stock for my 460 would you guys get those or just the autolite plugs. I have always just used the standard autolite plugs in everything
Old Jan 30, 2014 | 01:23 PM
JEFFFAFA's Avatar
JEFFFAFA
If you have a stock coil don't get the platinums. Harder to send the spark through platinum. If you have a "hot" coil then they would be ok. I'd stick with the standard Ford Motorcraft spark plugs. Of course I am a Ford Partsman..........................
Edit:
If any one wants the Ford Motorcraft spark plug part numbers for their application let me know.
Examples:
Big Plug.......(13/16" socket).........Usually standard heat range......suppressor plug for no radio noise.......BSF42C
big plug..........same.................... One heat range colder.............................same........... .....................BSF32C
Peanut plug..(5/8" socket)............usually standard heat range.....................same.................... ............ASF42C
Peanut plug..........same................One heat range colder.............................same........... .....................ASF32C
Old Jan 31, 2014 | 03:29 PM
CougarJohn's Avatar
CougarJohn
You are wasting your money on any of this hi-tech aftermarket crap. The opening of the points creates an electrical disaster in the secondary circuit. Something like 20,000 volts which causes the plug arc. The wire has a resistance of about 1,000 ohms. The plug electrode has a resistance of .01 ohm. Once the arc initiates, the cylinder fires.
Stay with the Ford products.
Semper Fi
msasteeler
6.2L V8
13
Nov 27, 2019 09:42 AM
luvcycles 2
Modular V10 (6.8l)
Jun 4, 2010 09:19 PM
garysorenson
31
Jul 19, 2008 11:23 PM
tw
Electrical Systems/Wiring
Mar 18, 2003 01:37 PM
