Offroad & 4x4
Bumpers!!
Old Jan 17, 2010 | 08:02 PM
  #271
tbenks's Avatar
tbenks
Originally Posted by kingford72
http://i649.photobucket.com/albums/u...2/DSC00014.jpg heres mine I have to get some updated pics its done now
wait for it, wait for it..............
Old Jan 18, 2010 | 01:20 AM
  #272
Prozon's Avatar
Prozon
KingFord72's Bumper
It looks like you just cut the ends off a stock bumper and welded some things to it. Am I correct? Also, you do have support for that reciever tied into your frame right? You can't just weld straight to your bumper and expect great support. Same with those loops you welded on, you can't expect them to hold without being tied into the frame. Your going to bend the crap out of that stock bumper if you try to recover something that way.
Old Jan 18, 2010 | 01:24 AM
  #273
9.ford.5's Avatar
9.ford.5
good call LOL
Old Jan 18, 2010 | 11:03 AM
  #274
tbenks's Avatar
tbenks
Originally Posted by 9.ford.5
good call LOL
no lol, i was waiting for prozon to make fun of his bfg at's, but i guess prozon only makes fun of my bfg ats
Old Jan 18, 2010 | 11:34 AM
  #275
86sixbanger's Avatar
86sixbanger
you can't just assume that's a stock bumper with the ends cut off. How do you know it's not a heavy duy piece of rail that's heavily gusseted and supported and fastened to the frame with grade 8 bolts? just sayin.
Old Jan 18, 2010 | 11:58 AM
  #276
kjett's Avatar
kjett
Because you can tell by the bends it was a stock bumper, either that or a piece of gutter rail. Jus sayin
Old Jan 18, 2010 | 01:21 PM
  #277
Prozon's Avatar
Prozon
x2
Thats what leads me to believe it is just a stock bumper, the bends and such look like one. I'm not trying to be a dick, i'm just saying that looks unsafe.
And thats pretty bad if you see ME saying something looks unsafe.
Old Jan 18, 2010 | 04:15 PM
  #278
kingford72's Avatar
kingford72
its 1/4" plt that is bent to match the contour of the stock bumper, the clevis mounts are 1/4" that go through the bumper and bolt to the side of the frame (and still uses the stock bumper mounting holes), and then on the front is 3/4 pcs to make the rest of the thickness if you know what I mean, and the same for the receiver tube it goes the whole way through and is gusseted in the back, not in that pic are the turn backs that go 10" back to guard the lower fender all 1/4 plt and there is also a prerunner style hoop on it.
Old Jan 18, 2010 | 04:50 PM
  #279
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
should be fine if it is properly connected to the frame, and properly gusseted and reinforced... only one way to find out i guess.
Old Jan 18, 2010 | 09:27 PM
  #280
RAF150's Avatar
RAF150
http://picsramsey.shutterfly.com/27#30
Old Jan 18, 2010 | 09:43 PM
  #281
kjett's Avatar
kjett
So is the winch to pull you off the speed bumps at the local mall?
Old Jan 18, 2010 | 09:46 PM
  #282
RAF150's Avatar
RAF150
Yes and to pull various parts of your truck off
Old Jan 18, 2010 | 09:48 PM
  #283
RAF150's Avatar
RAF150
Haha, jk....won this setup at a local store. Wasn't exactly going to say no to it. Has been useful in the snow with friends.
Old Jan 18, 2010 | 09:52 PM
  #284
kjett's Avatar
kjett
I use my reese mounted winch to pull the idiots out of the ditch when they get stuck in the snow while I'm out plowing in my stupid duty. I actually used it today to help me pull a tree down. Climbed up about 30 ft of a good sized oak, looped a chain through a notch, hooked the winch to it, had my buddy keep pressure on the winch while I cut the notch cause it started to lean backwards! Then had him put more pressure on while I did the last cut to bring it down. Love that thing!
Old Jan 18, 2010 | 09:59 PM
  #285
RAF150's Avatar
RAF150
Haha, well I don't think you'll see me out there Not in a ditch anyway.
Yes agreed, winches have many uses!
