hpop reservoir screen
Old Sep 30, 2009 | 06:30 PM
speedracer1000's Avatar
speedracer1000
is there anything i need to do with the screen when i put it in, it doesnt fit very tight and i filled it with oil and after a while the end of the screen starts to lift up a little off the block. is there some way to fasten it in or do i just let it go?
Old Sep 30, 2009 | 06:37 PM
koboss1's Avatar
koboss1
just let it go
Old Sep 30, 2009 | 07:21 PM
barnbridge's Avatar
barnbridge
When changing the oil cooler should the screen be replaced or can it be cleaned and reused?
Old Sep 30, 2009 | 07:44 PM
koboss1's Avatar
koboss1
i might be wrong but i think you have to do alot of re and re just to get at the hpop screen in the centre of the top engine?
Old Sep 30, 2009 | 08:21 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
It's only about a $14 part and they're pretty flimsy - I would change it before trying to clean and re-use it.
Old Sep 30, 2009 | 10:10 PM
silverstang's Avatar
silverstang
I would say about 70% of the time the screen is tore whenever you go to do an oil cooler. I ALWAYS replace them just to be safe. Your already in there, might as well. Also, it just sets in there.
Old Oct 1, 2009 | 06:55 AM
HeavyAssault's Avatar
HeavyAssault
If it's cheap then just replace it.
Old Oct 1, 2009 | 01:32 PM
UGA33's Avatar
UGA33
The cooler will hold it down. Definitely replace it though. Cheap insurance
astamp78
6.4L Power Stroke Diesel
Jan 23, 2017 11:06 AM
ungerp
6.7L Power Stroke Diesel
Apr 4, 2014 04:50 PM
Quick444
15
Jun 2, 2009 12:20 PM
zavierbr
Feb 28, 2009 07:27 PM
Whisperinghorse
Sep 19, 2007 06:54 PM
