Hey guys,
I'm going to do some well needed work on my truck tomorrow and the first place I would like to start is on that screen that you guys said is located in front the fuel bowl. The problem is that I look around the fuel bowl and I couldn't located the area that the screen is located. I would like someone with pic's or direction on how to located the "screen". Thank you
A screen in the fuel bowl? I don't know of any screen in the fuel bowl. Just the fuel filter. The only screen i know of is in the fuel tank. If there is a screen in the bowl i would like to know so i can check mine.
OK,
Where is the screen in the fuel tank located? I'm having some slightly hesitation when accerlerating off the line, so I'm try to fix anything that may have contributed to the problem. I'm going to clean the EBPS and the tube also.
i think what your talking about is the "fuel filter" itself. there are a couple of differant style fuel filters and one of them, "like the one Dan posted for you in guzzle's psd fuel filter" has a white screen like filter surrounding the filter itself.
its all one piece so you can't replace just the "screen", you need to buy a fuel filter and go through "guzzles" instructions to see how to do the install. its pretty basic.
and as far as the hesitation goes a dirty or clogged up fuel filter can deffinately cause a problem.
