Turbo V10 Excursion
Old Oct 9, 2009 | 11:48 AM
  #91
bill11012's Avatar
bill11012
Modular motor junkie
cool, rep sent.
2 questions.
1 will the 4R100 take the HP?
2 Will this setup fit under the hood of a V10 E350 van?
Old Oct 9, 2009 | 12:35 PM
  #92
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Originally Posted by bill11012
cool, rep sent.
2 questions.
1. It may, but with a few mods like a shift kit and better torque converter things will hold up better.
Old Oct 9, 2009 | 12:57 PM
  #93
Stewart_H's Avatar
Stewart_H
Jeff, you probably already answered this question, but who did the welding and fabrication? Did you do the work or did you have a shop follow your specs?
Either way, the fab work on that is top notch!
I wanna know what your Ex does in the 1/4 mile!!!!
Stewart
Old Oct 9, 2009 | 05:55 PM
  #94
wylecoyote's Avatar
wylecoyote
Very well built. Great Job.
Old Oct 10, 2009 | 11:28 PM
  #95
bdunaway78's Avatar
bdunaway78
Im interested. Can't wait for more details.
Old Oct 11, 2009 | 08:00 AM
  #96
V-EX-10's Avatar
V-EX-10
Are they for sale yet ?
Are they for sale and if so what will it cost including shippng to Miami, FL. I am beside myself waiting for your response. I have always thought of trickng out my Ex. So this is the begining !
Old Oct 11, 2009 | 07:59 PM
  #97
turbo10's Avatar
turbo10
Ok Guys, here is my delima. I have contacted everyone I purchased parts from for my turbo build. No one can give me a definate answer on bulk pricing. I can get the hot side built, cold side constructed with MAF block welded in, I can provide the MAF adapter harness, MAF sensor, I should be able to get the injectors at a deal if they ever get back to me. As for the fuel side, the stock pump with a pump booster will be good for 350 RWHP, If you want more you will need to install a larger pump in the tank, I installed larger SS pressure and return lines plus Walbro pumps in the tank with a custom fuel hat unit that got rid of the stock pump that sits on the bottom of the tank in a fuel module unit. I was planing ahead for a built engine with forged rods, pistons and maybe another turbo. You guys can get the same pricing for the rest, I just shopped around on ebay and doing Yahoo searches for the best pricing. I am working with my tuner to figure out a way to provide tunes for various vehicles with different gear ratios and so forth. If anyone would like to give their .02 just chime in. If someone was looking to just get another 100HP at the wheels it wouldn't be that bad of an upgrade. Let me know what you guys think. I know alot of people wouldn't want to pull all the factory fuel lines off the vehicle and bend new lines up like I did.
Jeff
Old Oct 12, 2009 | 11:20 PM
  #98
Husky44's Avatar
Husky44
VERY INTERESTED!!!!
I'm looking for a reasonable bolt-on setup, not squeezing the last 10% of potential out of it. So no, I don't want to spend a lot of time re-doing fuel systems, etc.
Suggestion: Maybe do something like Roush, Saleen, and others do: Stage I, Stage II, ...???
Definitely interested in the dyno numbers. How much of your current performance increase do you attribute to the increased fuel flow, vs turbo, etc?
I'm not real clear on what you're using for the intake now? Are you currently feeding into the stock EX intake, and working up the Lightning intake mod for another improvement, or are you already running a modded lower intake?
Keep the details coming!
Your fabrication skills are awesome!!!
Old Oct 13, 2009 | 12:38 AM
  #99
Fordsfoorever's Avatar
Fordsfoorever
Thumbs up
Hi Turbo10
Great Mod!
I would be interested in a kit if available. One thing though, Do you have a heat shield worked out for placement under the hood to protect from a fire or tarnished paint on top of the hood? Simply put is the hood protected from heat? Also did you use your old fuel lines as a guide to make the SS lines (ex. exact bends,fittings,flaired ends)?
Thanks
Paul
Old Oct 14, 2009 | 12:21 AM
  #100
mvanbeelen's Avatar
mvanbeelen
I can only say I MUST HAVE ONE. Also, I feel bad for you guys living in Commie Cali. Here in Michigan, it is no sniffer, no rules. Man, do I ever want this on mine.
Old Oct 14, 2009 | 07:13 AM
  #101
flatlander84's Avatar
flatlander84
FYI there's a place called inlinetube.com that can make CNC tubing. If you send your lines in they can make a template that can be reproduced. That is if you want to make a kit to sell to the public.
Old Oct 14, 2009 | 10:15 PM
  #102
Monster-4's Avatar
Monster-4
WOW how did I miss this! That's awesome! Wish you would have brought it to our little pulling contest. I would have love to see that thing up against Crazy's 6.4 PSD.
https://www.ford-trucks.com/forums/8...entral-oh.html
https://www.ford-trucks.com/forums/8...-part-2-a.html
I'll be following this thread from now on.
Old Oct 15, 2009 | 07:55 PM
  #103
flagford's Avatar
flagford
7 lug Excursion
Hey - can anyone tell me about the 7 versus 8 lug hubs/wheels used by Ford around 2000? I have a 2000 Excursion 4x4 V10 I just got and realize that it only has 7 lug wheels. My 1999 F250 ext cab 4x4 truck has what I thought was the standard 8 lug. Any insight would be great, thanks!
TV
Old Oct 15, 2009 | 08:03 PM
  #104
cbradford's Avatar
cbradford
TV
You might want to start a new thread for this and welcome to FTE.
Old Oct 15, 2009 | 08:36 PM
  #105
Stewart_H's Avatar
Stewart_H
TV
It has 8 lugs. Remove the plastic decorator hub cover off and you'll see 8 lugs.
But Chris is right. If you're not adding to the thread, or asking a specific question regarding the topic of the thread, in order to get a broad response for your question, you should always start a new thread.
Also, like Chris said, welcome to FTE!
Stewart
