Ball Joint Squeal
Old Sep 20, 2009 | 06:50 AM
mxracer3276's Avatar
mxracer3276
Ball Joint Squeal
Alright so what i thought was my power steering pump squealing is actually coming from one of my driver side ball joints. Is this common for them to squeal when they get worn out? If they need to be replaced, would it be cheapest to get these from Ed?
Old Sep 20, 2009 | 07:08 AM
big poppa's Avatar
big poppa
Never heard of a ball joint squeal, sure its not your hub or brakes or rotor??
Old Sep 20, 2009 | 07:21 AM
mxracer3276
It only does it when i turn the wheel. I will get a picture up to show exactly where the squeal i coming from?
Old Sep 20, 2009 | 07:45 AM
mxracer3276
The squeal is coming from somewhere in the circled area:
Old Sep 20, 2009 | 08:44 AM
mueckster's Avatar
mueckster
Looks like that would be the culprit. You could try to pry up the rubber boot and spray in some lube. This could help until it is replaced. With it raised up, the lube can under the ball of the joint.
Old Sep 20, 2009 | 09:12 AM
pbr man's Avatar
pbr man
Mine is doing the same thing on the passenger side. I replaced the driver's side a couple of months ago with Napa Premium ball joints, but the passenger side is still tight but it squeaks when I turn the wheel.
BAD RONALD
Apr 24, 2014 02:39 PM
TMattson
1997 - 2003 F150
Aug 25, 2011 08:58 PM
97biostroke
Mar 21, 2011 09:34 AM
loudford
Dec 30, 2010 07:36 AM
