Sponsored by: Auxito
Squeal When Turning
Old Aug 25, 2011 | 07:02 PM
TMattson's Avatar
TMattson
Squeal When Turning
My '02 F-150 4x4 has been intermittently making a squeal on sharp turns. I only hear it at low speeds, usually when pulling in to a parking spot. It sounds like a tire squeal and only lasts a second. I recently lubed the pitman arm with a grease needle and checked the ball joints for play. Has anybody else experienced this?
Thanks
Old Aug 25, 2011 | 08:29 PM
steve(ill)'s Avatar
steve(ill)
this is common with trucks that have a limiti slip rear end. the LS clutch is trying to lock the two rear wheels together. AS you turn corners, the clutch needs to slip so they turn different speeds. You can get a 7 oz tube of friction modifier at Auto Zone and add to the rear axle gear lube if it gets too bad. You want a very slight grab so you know the clutch is functioning. If it grabs constantly it is anoying and will wear premature. It only happens at low speed, normally from a stop during a sharp turn.
Old Aug 25, 2011 | 08:58 PM
TMattson's Avatar
TMattson
Thanks for the reply. I forgot to mention some things, I have a 3.55 regular rear axle, code 19 on the door sticker. Also the sound seems to be coming from the front end. Sorry for the mix up.
Thanks
orangebanzai
1997 - 2003 F150
Oct 14, 2015 08:21 PM
DawnPatrol
Apr 9, 2013 08:33 PM
kbalz
1997 - 2003 F150
Mar 17, 2013 10:11 PM
scott76 f-250
1997 - 2003 F150
Mar 3, 2013 06:26 AM
tiger_698
1997 - 2003 F150
Apr 7, 2011 08:55 PM
