Driver side front end squeal
Old Apr 24, 2014 | 09:29 AM
BAD RONALD's Avatar
BAD RONALD
'04 E350 has a noise that sounds like brake squealers that happens only when turning hard right and accelerating from a stop. Definitely from driver side front. There is no squeal when brakes are applied, no steering wheel vibration and zero bearing hum. Not a belt squeal nor power steering whine. Ball joints were replaced last September.
Checking here first before inspection; ideas are welcome.
Old Apr 24, 2014 | 11:15 AM
JWA's Avatar
JWA
How loud is this squeal?
Old Apr 24, 2014 | 11:52 AM
BAD RONALD's Avatar
BAD RONALD
Audible with windows closed. Think brake squeal of a heavy truck stopping at a traffic light. Not a grinding sound or a moan. Disappears when driving straight away.
Old Apr 24, 2014 | 02:26 PM
JWA's Avatar
JWA
I was thinking if audible but faint maybe the ABS sensor bracket has come in contact with the rotor?
Maybe lay under the van nearest the offending wheel, have someone turn the steering wheel lock-to-lock. If there's anything rubbing the rotor while turned one direction or another it might present itself visually.
Never had this happen to me or hear (or recall) anyone else here having this same problem---very intriguing.
Old Apr 24, 2014 | 02:39 PM
BAD RONALD's Avatar
BAD RONALD
This just started and I haven't even glanced at it yet. I'll follow up with findings. Thanks for your input.
gbaumgar1
Mar 14, 2018 06:35 AM
yechave
Jan 26, 2006 10:58 AM
amm888
Aug 14, 2005 10:24 PM
77c3
Oct 17, 2004 05:27 PM
