Headlight bulb question
Old Sep 8, 2009 | 10:18 AM
Spaggs's Avatar
Spaggs
I just put in some bright headlights and now my electrical system has gone haywire. One light is bright and the other is not. I tap on the lens and they switch. Once, both went out on me. Do I need a relay or something?
Spaggs
Old Sep 8, 2009 | 10:23 AM
tdappleman's Avatar
tdappleman
I think we need more information on exactly what was changed? Just a higher wattage bulb in the existing socket? Have you removed the bulbs and gone back to stock wattage to see if the problems persist?
Old Sep 8, 2009 | 10:34 AM
jdadamsjr's Avatar
jdadamsjr
Wow - sounds like fun - NOT
Hmmmm...
Debug mode...
is the headlite bulb the only thing that changed ?
is it possible one of those sharp corners nicked a wire and is shorting ?
What make model engine ?
What wattage did you put in ?
good luck
on edit - td and I typed at the same time - he just types faster than me I guess
Old Sep 10, 2009 | 06:37 AM
Spaggs's Avatar
Spaggs
The only thing I did was replace the bulbs. I'll try flipping them around this weekend and see what happens.
Spaggs
Old Sep 10, 2009 | 08:48 AM
BAJI26's Avatar
BAJI26
Make sure the backing that secures the bulb housing is seated properly!
Old Sep 10, 2009 | 02:44 PM
VaSheriff's Avatar
VaSheriff
I can warn you about the high output eBaY junk..... whatever you put in, check the plug going into the headlight after they have been on for about 15 to 20 minutes. If the plug and wiring is hot as a firecracker you need to switch back to a normal headlight. The "super white 5000K" bulbs I bought on eBaY were frying my plug and wiring.
I replaced them with the 4300K Sylvania Silverstar. The plug and wiring now have no significant heat associated with them at all.
Old Sep 13, 2009 | 04:45 PM
Dakrri's Avatar
Dakrri
Hi Vasheriff,
Did you do the low and high beams....was it an easy job/upgrade? I hate how dim the factory lights are. Thanks Dakrri
Old Sep 13, 2009 | 05:16 PM
SkySkiJason's Avatar
SkySkiJason
Originally Posted by Dakrri
Hi Vasheriff,
I'm pretty sure the sheriff was reffering to zenon bulbs - not some wanna-be HID set up... (please don't waste your money on hurting my eyes!) Really want HID's? Buy some HID driving lites for your bumper - your fellow drivers will thank you AND you will actually be able to see farther than some hackjob HID 'conversion'.
Your issue sounds like a ground problem to me. If you are unlucky enough to have 9008/H13 bulbs ('05-'07 headlights) and you 'upgraded' to higher wattage bulbs - well, there's your problem! Look at the headlite pigtail, the center pin is the ground... I have Hella bulbs from www.rallylights.com - no need for any more light and I drive ALOT at nite.
The relay harnesses just insure full battery power to bulbs, stock wiring can allow quite a drop in voltage.
Old Sep 13, 2009 | 06:48 PM
VaSheriff's Avatar
VaSheriff
I'm pretty sure the sheriff was reffering to zenon bulbs - not some wanna-be HID set up... .
Yes, the junk that's suppose to look and be brighter.
It isn't. It just heats the wiring up to frying temperatures.
Old Sep 13, 2009 | 06:57 PM
SFeintuch's Avatar
SFeintuch
Like SkiSkyJason said It is a bad ground,
Spaggs
Feb 26, 2010 04:48 AM
Spaggs
Sep 15, 2008 06:09 PM
Spaggs
Sep 4, 2008 02:02 AM
Spaggs
May 18, 2007 01:47 PM
Spaggs
Apr 27, 2007 02:19 PM
