cps question
Old Sep 4, 2009 | 09:20 PM
willeo6709's Avatar
willeo6709
cps question
my 2002 7.3l excursion recently started dieing, falling on its face only to not die and keep on running. Figuring a CPS and needing ti the next day I got a grey cps from ford. That fixed most syptoms, but created another. Now I have a mild surging between 600-1000 rpm, generally when the engine is warm. I do have a diablo chip, but it is otherwise stock excpet for the gauges. Do I just need a black cps or do I have another problem? My bet is a black IH cps might solve the issue.
Old Sep 4, 2009 | 09:24 PM
hucka1a's Avatar
hucka1a
When I had the grey CPS I had a rough idle. More folks will be along shortly.
Old Sep 4, 2009 | 10:11 PM
F350-6's Avatar
F350-6
You could always set the truck back to stock and see what difference that makes. Like Huck said, the "new & improved" cps typically causes a rough idle and contribution faults.
Old Sep 4, 2009 | 10:17 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
the weird thing about these gray ones is that it seems to be hit or miss with them. i had mine changed during the recall and then i read so much bad about them i bought a couple of the remaining black ones and stuck one in. i havent noticed a difference between the two. just my experience though.........
Old Sep 4, 2009 | 10:20 PM
willeo6709's Avatar
willeo6709
this particular chip is non adjustable... it was there when I bought the vehicle. It does good on economy but I like the DP F6 in the F350 better. I suppose I could pull the chip and see what happens. I recently replaced the cps on the F350 with a napa cps and had no issues, but napa did not have one when i went to get one for the ex.
Old Sep 4, 2009 | 10:30 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
If you want to try a black one I have been able to find a couple more.
Old Sep 5, 2009 | 01:48 AM
4inchlovin's Avatar
4inchlovin
I would take the chip off and try. Then swap the CPS.
strokin'_tatsch
228
Feb 7, 2026 07:00 AM
Diesel 724
Jan 24, 2012 07:43 AM
MauleOne
35
Oct 20, 2011 10:50 AM
Bertelrud
Jun 2, 2009 07:41 AM
maevans
Nov 30, 2005 06:53 PM
