Okay so my 04 f150 has all of a sudden decided to stop showing the compass and odometer. At first they started to blink then it went out. Does anybody know any fixes or were to point towards. any help would be appreciated.
I have this same problem but only when my truck sits out in the sun for a while on hot days. I'm interested to know what it might be as well.
It has to be light (as opposed to heavy) connections behind the instrement cluster. I haven't had to remove mine on this truck, but on other vehicles I've owned, they have a plactic plug that fits into the back of the cluster. After awhile the plastic looses it's tension and results in poor contact if any at all. A good certified shade tree mechanc should be able to come up with a fix.
IS THE ODOMETER COMPASS BLANK OR INTERMITTINT OR NOT WORKING CORRECTLY?IF YOU ANSWERED YES ,I HAVE THE SOLUTION FOR YOU.REPAIR SERVICE TO REPAIR YOUR INSTRUMENT CLUSTER FOR THE FOLLOWING.... ALL 2004-2008 f-150 pk only
WE ONLY OFFER REPAIR ON THE ODOMETER/COMPASS/TEMP THIS WILL WORK FOR YOU............IVE REPAIRED OVER 6000 CLUSTERS
CALL ME @479-652-2258
BRIAN'S SPEEDOMETER REPAIR
seriously dude, lose the giant text and try to contribute a bit around here and folks MIGHT bother to consider dealing with you.
