Sponsored by: Real Truck
Brake controler placement
Old Aug 28, 2009 | 04:31 PM
woody367's Avatar
woody367
I just bought the Prodigy brake controler for my 04 F250. Was wondering where most people place it? I have a 2-way radio and Sirus mounted in the middle under the stock radio and really don't want it on the left so I hit my leg getting in or out. So where should it go?
Old Aug 28, 2009 | 04:41 PM
adbscu's Avatar
adbscu
we have a prodigy
in an 05 and we have it the little "glove box" under the slot for the original brake controller unit and aux switches.
Works pretty well: it's hidden/out of the way while not towing and it's easy to adjust and check the status while towing
Old Aug 28, 2009 | 04:44 PM
MikeMcCasland's Avatar
MikeMcCasland
I'll do you one better. Here are a bunch of pictures:
https://www.ford-trucks.com/forums/8...-pictures.html
woody367's Avatar
woody367
I put the upfitter switched in my cubby so thats out. and just below the cubby is my sirus
Old Aug 28, 2009 | 06:56 PM
Greg B's Avatar
Greg B
When installing the Prodigy in My 06 F150, the instructions said to keep the controller at least 18" away from the CB radio as it could interfere with the operation of the conroller. So I mounted it on the left of the steering column and do bang my knee occassionally.
Old Aug 28, 2009 | 07:02 PM
QwkTrip's Avatar
QwkTrip
For the OP, are you a particularly tall person? I have my controller mounted to the bottom dash below the cubby hole. Not even close to touching it with my leg, and I even have my seat further forward that guys with an auto because I have to reach the bottom of the clutch.
Old Aug 28, 2009 | 07:34 PM
MikeMcCasland
I'm 6'5" and I have my P3 mounted in the exact same spot. No issues here.
Old Aug 28, 2009 | 07:55 PM
QwkTrip's Avatar
QwkTrip
See, without knowing the scale I thought you were holding a Chiwawa, not a Labrador.
Old Aug 28, 2009 | 08:47 PM
woody367's Avatar
woody367
[quote=QwkTrip;7878662]For the OP, are you a particularly tall person? I have my controller mounted to the bottom dash below the cubby hole. Not even close to touching it with my leg, and I even have my seat further forward that guys with an auto because I have to reach the bottom of the clutch.[
I am 6'2". In my 99 Yukon I have the controler on the left and hit my shin. I will check a few places tomarrow and see If I can come up with somethind. I will also post a photo so you can see whats in the way.
Old Aug 29, 2009 | 08:20 PM
rebelyell618's Avatar
rebelyell618
here is where i have mine
Old Aug 29, 2009 | 08:46 PM
QwkTrip's Avatar
QwkTrip
I think anybody would have that problem with the controller on the left. That's why we mount it on the right.
If you're concerned about having the controller and CB close to one another then maybe you can mount the controller on top of the dash or in an overhead console? It needs to be within easy reach so you can throw the brakes manually.
Old Aug 29, 2009 | 10:19 PM
woody367's Avatar
woody367
Can not figure how to post a photo. Help please
Vanet
Dec 17, 2010 11:14 AM
mfesperman
6.4L Power Stroke Diesel
Aug 8, 2007 02:47 PM
craiginsocal
Feb 14, 2007 07:45 PM
Bob Wire
Nov 13, 2004 11:15 PM
99xlt4.04x4
1983 - 2012 Ranger & B-Series
Jul 29, 2004 09:44 AM
