Wipers dont work..
Old Aug 27, 2009 | 08:11 PM
BombThreat's Avatar
BombThreat
Wipers dont work..
When trying to turn on the wipers my wiper relay module would click with every increment of the dial/speed. Also it will click randomly when the truck is running. So i found one on ebay and swapped it out. Still does the same exact thing. But I have not tested to make sure the wiper motor did no die... Do you guys know what wires need to be jumped on the motor to test it?
Old Aug 27, 2009 | 08:25 PM
joe f350's Avatar
joe f350
dose anthing onur truck work right lol did u check the fuse of the wiper motor
Old Aug 27, 2009 | 08:37 PM
BombThreat's Avatar
BombThreat
its been a project... getting close to done. yes i checked the fuse
Old Aug 27, 2009 | 08:43 PM
mountaineer27's Avatar
mountaineer27
just tie a string to the wiper and run it in through the window. its rather annoying but it works and is cheep!
Old Aug 27, 2009 | 08:50 PM
joe f350's Avatar
joe f350
check the motor would be the next step
Old Aug 28, 2009 | 12:20 AM
rupejosh's Avatar
rupejosh
when mine did that the plug on the wiper motor had came half off so i pulled the plug off and cleaned it with electric parts cleaner and plugged it back in and works just like new.in 3 years i had to push the plug back on twice
Old Aug 28, 2009 | 08:45 PM
Vince dEon's Avatar
Vince dEon
What rupejosh said is what happened to me.
The delay module is only one part of the electrical chain; there is also the control itself and the motor (plus fuses).
Old Aug 31, 2009 | 02:18 PM
equium's Avatar
equium
You may have the same problem I had. My wipers would sometimes work. A bang on the dash would get them to operate when they stopped.
Notice that the delay control module is just above where the parking brakes BANGS when you release it. All this banging may have cause the solder joints to loosen on the delay control board. Here's what I did:
Remove the delay control board
dis-assemble it until you see the circuit board. look at the solder points. I could see right away mine were knocked loose.
Take a soldering iron and re-heat the solder joints to re-melt the solder to make new, clean connections.
OR, if you're handy with solder, remove all the old solder and re-solder with new.
Re-install the delay module and try it out.
I have taught myself to put my foot on the parking brake when releasing it so it doesn't bang under the dash.
Good luck
danny
Old Aug 31, 2009 | 03:08 PM
Hamberger's Avatar
Hamberger
93' Windshield Wiper
I had the same problem on my 93' F250 a few years back.
Your problem is most likely worn out contacts on the cover of the Windshield Wiper Motor/Gearbox. I think the 93's had a problem with poor contacts, either bad material or just not designed right in the first place.
The cheapest thing to do is to replace your windshield wiper motor and gearbox.
If the contacts don't send the right electrical signals to the black governor control box behind your glove box then the wiper operation goes all haywire. Somtimes they work, sometimes they don't, sometimes they start when you don't want them to start, sometimes they won't come on, and sometimes that darn things won't shut off when you want them too.
You can check the contacts by pulling off the round looking cover on the gearbox, you will see some sliding electrical contacts that will have worn off or will have badly grooved the copper/brass disk they ride on.
Your motor is probably fine but you won't be able to buy the contact separeately so you might as well buy a new Windshield Wiper Motor/Gearbox.
PS my fan blower motor wore out the same way. The carbon brushes were completely gone and it just stopped on day. When I took it apart there was nothing left of the brushes, even the springs had worn away and the commutator was deeply grooved. In the nutshell the blower motor was completely worn out.
Good luck,
Sebastian.
Old Aug 31, 2009 | 06:55 PM
BombThreat's Avatar
BombThreat
thanks for the help guys. i went ahead and bought a new reman motor and it now turn on and works... but only on high, semi-high and the next lower speed. all the others will only work once when they are first clicked onto. and to be honest im happy with just that.
i think i will crack open that relay module since i have a spare and make sure everything is tight in that.
Old Sep 1, 2009 | 11:33 AM
Hamberger's Avatar
Hamberger
[but only on high, semi-high and the next lower speed. all the others will only work once when they are first clicked onto. and to be honest im happy with just that.
i think i will crack open that relay module since i have a spare and make sure everything is tight in that.[/quote]
The way you describe it, it sounds like you may also have a problem with your windshield wiper govenor box. (Black Box behind your glove compartment)
A new governor box runs around $100, or so from Ford.
Best of luck,
I know how annoying it is when your wiper do funny things.....
Seb....
Old Sep 1, 2009 | 04:09 PM
BombThreat's Avatar
BombThreat
thats the same box ive been referring to as the wiper relay module. ive swapped it out and it doesnt change anything
Old Sep 1, 2009 | 06:26 PM
Hamberger's Avatar
Hamberger
Ouch, about the only things left then is your actual switch on your steering column or possibly a bad wiring connection.
Good luck,
Seb....
Daddyo's garage
20
Dec 22, 2016 06:38 AM
mountngoat
Nov 20, 2016 07:44 PM
Gear9250
1978 - 1996 Big Bronco
Feb 26, 2016 10:42 PM
BaggedMerc
Sep 12, 2015 10:39 AM
Nightrain
Aug 5, 2005 11:41 AM
