Vacuum Wipers
Old Sep 11, 2015 | 05:17 PM
BaggedMerc's Avatar
BaggedMerc
Vacuum Wipers
Hi Guys,
I have no experience with vacuum wipers.... so maybe this is something small.
I have a 51 Mercury M3 and it has vacuum wipers. Motor is a SBC 305 TPI if it matters.
When I tested the wiper motor with a small piece of hose right off the plenum, it worked. Now withe everything buttoned up, I have a "T" to the MAP sensor and to the wiper motor.
The wiper motor won't work now. Ideas???
Thanks John
Old Sep 11, 2015 | 05:53 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Originally Posted by BaggedMerc
Hi Guys,
Thanks John
I don't know much about vacuum wipers either, but it sounds like you lost the vacuum somewhere. Plug the other side of the tee and see if they work.
Old Sep 11, 2015 | 05:57 PM
JWC 3's Avatar
JWC 3
Use a dedicated vac line for the wipers and another for the map.
Old Sep 11, 2015 | 08:07 PM
BaggedMerc's Avatar
BaggedMerc
There is vacuum there if I pull the hose off the motor. Not sure how much should be there though... no gauge.
No sure where else to tap. The plenum has 3 ports and I'm using them for: MAP, brake booster, and Fuel pressure Reg.
Old Sep 11, 2015 | 08:22 PM
56panelford's Avatar
56panelford
Any pictures of this bagged Merc? Please and thank you.
Old Sep 11, 2015 | 08:31 PM
BaggedMerc's Avatar
BaggedMerc
Just realized there are 2 vac ports. Derp.
Will swap tomorrow and test lol.
Old Sep 11, 2015 | 08:34 PM
BaggedMerc's Avatar
BaggedMerc
I have a build thread in here somewhere
Old Sep 11, 2015 | 08:37 PM
56panelford
That looks cool, I'll have to look for your build thread. You should put it in your signature.
Old Sep 11, 2015 | 09:30 PM
JWC 3's Avatar
JWC 3
I like! nice looking truck .
Old Sep 12, 2015 | 05:27 AM
pbsdaddy's Avatar
pbsdaddy
Try a bit of lube on the vacuum unit and arms. Also, check the hose for cracks or other leaks. Last, spray some water on the windshield before trying the wipers. I've owned a few vehicles with vacs and none of them liked dry windshields.
You might want to consider a vac can.
Old Sep 12, 2015 | 10:39 AM
AXracer's Avatar
AXracer
Vacuum motors on wipers are really simple buggers. Don't be afraid to disassemble it, clean it and relube all (few that there are) moving parts with a good light bodied grease like white lithium. It will usually have it working better than new.
fordf348
Nov 24, 2014 02:46 PM
tiger_698
Jul 18, 2011 07:26 AM
bobbytnm
23
Aug 10, 2006 01:56 PM
tp
Oct 23, 2004 07:18 PM
4byford
Jul 14, 2001 10:01 PM
