Injectors
Old Aug 25, 2009 | 10:00 PM
pstroker's Avatar
pstroker
Injectors
I have an 03 psd with 160 k i don't drive it but once a week now and its starting to give some trouble. First the fuel sender was working intermittently and now registers no fuel last when i drove it i put 1/2 tank so i know its not yet out of fuel.Tonight it would not rev 35-40 mph was a chore and even in neutral hardly spools up.its rattling too. I have a feelng injectors are going any advice will help..Thanks
Old Aug 25, 2009 | 10:29 PM
mueckster's Avatar
mueckster
Does it idle rough? Have a miss? Could be fuel pump or clogged filter. Have you changed your filter recently? If you have no SES light or codes set, it could be fuel pressure related. PCM doesn't monitor fuel pressure.
Old Aug 25, 2009 | 11:02 PM
Tenn01PSD350's Avatar
Tenn01PSD350
There is no spooling in neutral. Need a load for that. Where are you located?
Old Aug 26, 2009 | 02:07 PM
pstroker's Avatar
pstroker
I am in South fl .. it idles rough ....is there a lift pump in the tank that could be failing and is the fuel sender an integral part of the lift pump the sender failed about 100 miles ago
Old Aug 26, 2009 | 02:08 PM
pstroker's Avatar
pstroker
I change the filter every other oil change is there a filter in the tank could be clogged ?
Old Aug 26, 2009 | 02:58 PM
bassin88's Avatar
bassin88
i have a 2000 7.3 im having the same problem as you i have a cheap code reader mine says injector malfunction im lost i have a ses light on mine ive been told that its the vavle cover gasket harness i dont know wish i could help but i need help too
Old Aug 26, 2009 | 05:39 PM
bfife's Avatar
bfife
still plays with trucks
There is no pump in the tank. but the are fuel screens and mixing chambers in the fuel tank that will clog and give you fits.
Barney
Old Aug 26, 2009 | 08:53 PM
Izzy351's Avatar
Izzy351
Sounds like a huge boost leak to me. Rough running could be something else, depending how rough. But the big clue is no boost & low power...
Old Aug 26, 2009 | 09:13 PM
pstroker's Avatar
pstroker
Smile
OK dropped the tank,replaced the sender cleaned up the tank and screens (were pretty nasty) runs like a champ going to do the fuel filter tomorrow....thanks for the info
Old Aug 26, 2009 | 10:05 PM
mueckster's Avatar
mueckster
Glad to hear you've got it going your way.
Jerry Chaney
Jan 14, 2014 07:32 PM
jwolfe60
Jul 3, 2008 05:35 PM
coldnorthpole
Mar 3, 2007 07:19 AM
cjlawther
New Member Introductions
Dec 26, 2006 08:48 PM
ford f250sd
Modular V10 (6.8l)
16
Oct 20, 2003 09:39 PM
