Shut down on interstate
Old Jun 29, 2008 | 11:06 AM
jwolfe60's Avatar
jwolfe60
My 86' 6.9L F250 just died on the interstate going around 85mph and I don't this it is getting fuel to the injectors. I had the fuel pump tested and everything on it works fine, and I know that the injector pump is getting fuel to it. A couple of the injectors leak some around the return rings and when ever it rains hard I have fuel on the ground under the rear tank (but not just when I park it on dry days). It refuses to prime the injector pump to get fuel to the injectors now as well. Any suggestions???
Old Jun 29, 2008 | 02:54 PM
Dave Sponaugle's Avatar
Dave Sponaugle
jwolfw60,
Welcome to the IDI forum.
Turn the key to ON, and remove the wire on the IP, front drivers side.
Listen carefully, do you here a clicking noise from the IP?
Next remove the schrader valve from the fuel filter header and install a pressure gauge there.
When you crank the engine are you seeing any pressure?
How much?
Is the stock water seperator still in the fuel system?
The water seperator was a known point for air intrusion, which causes starting issues.
Old Jul 3, 2008 | 10:57 AM
jwolfe60's Avatar
jwolfe60
I hear a click when I remove and reattached the wire to the IP, I have an electric pump for the lo-pressure pump so I know that it is getting good pressure through the filter. Where can I find the water seperator? And any other suggestions?
Old Jul 3, 2008 | 12:43 PM
LilDuke's Avatar
LilDuke
I think Daves got it nailed down. Either a failed electrical component as it pertains to the shutoff selenoid, or a blockage.
Did it shut off like you turned off the key? or spit and spudder?
Old Jul 3, 2008 | 05:35 PM
jwolfe60's Avatar
jwolfe60
It just strait shutoff, no sputtering or anything.
gov2mod
46
Feb 17, 2019 01:26 AM
bossgobbler
15
May 5, 2011 05:04 PM
WishIhada7.3
Oct 31, 2010 09:22 PM
doorstop
Oct 25, 2010 11:16 AM
BobbyB
Oct 8, 2010 07:43 AM
