Fuel Injectors on a 93 F150
I have a 93 F150 and 1 of my fuel injectors is bad.
Is there a way to repair a bad fuel injector or am I stuck just buying a new one.
The fuel injector cleaner has been ran through it a many times and doesnt do any good.
I have heard that I should get the exact same injectors that are in the truck right now or the computer wont work right with the injectors. Is this correct?
I know they are pretty pricey. Around $85 bucks a piece correct??
Thanks for the help!
Immediately upon replacement of all 6 injectors, the engine ran like a top. The computer seemed to fish around a bit trying to figure out what fuel flow it wanted, but that settled down in just a few miles of around town. Took it up "sardine canyon" at a smooth 65mph in 5th gear, and it will lug smoothly at 900rpm in 5th going up a slight incline. At any rate, I couldn't be happier with the new injectors.
Also blew out the fuel lines and installed a new filter (on the frame rail), before hooking up the fuel line, and installed a new pcv valve, radiator cap and thermostat. Was pleased to note there was no rust or debris in the old filter, but when the engine fired up I was amazed. It reminded me of an old TV advertisement they used to have of a car that ran so smooth that they had some poor guy sitting in the back seat with a table, hammer and chisel whacking away at a big diamond to show how smooth the car ran. At any rate, the gearshift has absolutely no vibration anymore and the engine runs like a good six should! :-)
I bought a set from a junk yard a few years ago and they worked just fine. You can actually test them if want before you install them. I just did them one at a time, by holding them in the hole(Using a flashlight) having a helper crank the truck, look for squirting fuel(I had the wires for the other 5 disconnected so they wouldnt pulse)
I paid $50 for the whole rail...injectors regulator and everything.
I had the same problem last week and i know you dont want to spend money but heres what i did. after alot of thought i found a set of 19lb injectors from summit theyre accel and i installed them reset the ecu let the computer relearn itself and its never run better, more power too.
If you are going to change out injectors and you have any kind of mileage on the engne your going to be better off buyin a new set rather than hoping o rings will properly seal on the old injectors.
the truck takes 14 or 15 lb injectors but i went with 19s in case i ever decide to add a cam.
Once you replace the injectors and you may want to buy new upper intake manifold gasket to make certain you havea good seal so no air leaks or the engine will race.
Reset the ECU by disconnecting the battery for 10 minutes then let it idle for a while so the system can relearn itself after afew mileso f driving it should run like a dream
Patrick
Patrick
Patrick
Patrick
Now thats interesting. Did you keep track of your mpg before this, if so, post up your results over the next few weeks.
When I was replacing the intake gasket on mine, I found that the number 1 cylinder fuel injector porcelain on the end was cracked really badly. So, while I had it apart, I replaced it with a napa brand injector and have not had any troubles what so ever. My boss at work used to be a ford mechanic and he said that they would replace just one injector many of the times if it was the only bad one, with no bad results. About 1000 miles latter, everything is still fine with the engine running good and no trouble codes.
Food for thought
The stock 14 lb/hr injectors, actually flow more like 18~19 lb/hr injectors, due to the 4.9's higher fuel pressure setting, as injectors are flow rated at 43 psi.
Stock injectors should be good for 170-180 +/- HP, should be plenty for a cam swap on a stock engine.
Im just not so sure the computer can relearn the larger injectors or adjust the pulse width enough to compensate for the added potential flow, combined with the stock 4.9 fuel psi.
19 lb/hr injectors using the stock 4.9 fuel psi, are flowing more like 22~24 lb/hr injectors.
This is just rough estimates.
Still interested in how the larger injectors affect mpg, with no adjustment of fuel pressure.
havocx101
01-07-2022 11:24 AM
Brian Ski 44
06-26-2016 06:45 PM
Zombiemom
01-23-2016 03:59 PM
