adding lubricity?
Old Aug 26, 2009 | 01:04 PM
  #31
aklim's Avatar
aklim
Originally Posted by IABill
If you want the straight data and I am not promoting this other site, but
this is the most comprehensive data I have ever seen. I printed a hard copy from dieselplace dot com. search for: lubricity additive study results. It was done at the southwest research lab in the great state of Texas.
Results were in order of best lubricity to least:
#1. REG 2% bio diesel blend with 98% pump diesel
#2. Opti Lube XPD 13oz per 26 gallons
#3 FPPF RV,Bus,SUV Diesel treatment 5.2oz per 26 gal
#4 Opti Lube summer blend multi purpose 1.11 oz per 26 gal
#5 Opti Lube winter blend 6.5 oz per.....
#6 Schaeffer Diesel treat 2000 3.32 oz per...
#7 Super Tech Outboard 2-cycle TC-3W 16.64 oz per....
#8 Stanadyne lubricity formula 3.32 oz per....
#9 Amsoil Diesel concentrate 5.2 oz per....
#10 Power Service Diesel Kleen + Cetane Boost 8.32 oz per....
There is a lot more there Tried to scan & copy but I cant get it to work...
None of it addresses how the lubricity will affect anything in the real world. Nobody shows us what the point of diminishing returns is which is real important. All they allude to is "Some is good, more is better". Much like the supplements they sell at Walgreens. All they talk about is how my brand has more of this than yours. Not a word on bio availability.
Old Aug 26, 2009 | 09:04 PM
  #32
IABill's Avatar
IABill
Question
Did you locate & read it?
Old Aug 26, 2009 | 10:19 PM
  #33
aklim's Avatar
aklim
http://www.dieselplace.com/forum/sho...d.php?t=177728
Yes, I have read it and didn't think much of it. The only information I would consider valuable, and I use that term loosely, is the ranking of which snake oil, aka additive, is better than the other. Or as the Shania Twain song goes "That don't impress me much".
They seem to worship without question the magic number of 460. Why 460? Why not 400? 380? 200? As I have often asked and nobody can say with certainty "What is the point of diminishing returns?" Show me on a component or system level what the benefits of going from 520 to 460 is. Show me that for ever 10 points, the life is changed by X%. I realize even that won't be "real life" but it is reasonably close. Show me that by going from 520 to 460, the injector life is extended by say 10%. That will help me calculate the costs vs benefits. What happens when you go below 460? Again, no answer.
Yes, as a manufacturer, you bet I would be for any of these snake oils that will give any sort of improvement. Why? Because ever mile or day more you can go without a breakdown is a day or mile closer to the warranty going out. Best of all, it is on YOUR dime, not mine. Doesn't cost me a thing and it lowers my warranty coverage. Why not? As a consumer, I want to know what this "extension" is going to cost me. I want to know if it is going to cost me $10 to save $5 or vice versa.
Let me ask you this. If these snake oils do as much as the manufacturers like to think, why haven't they done a proper test instead of using these "studies" to infer you need their snake oil? After all, if you are selling it, isn't the onus on you to prove efficacy instead of trying to use these "studies" to hint at reasons why the consumer should buy their snake oil?
Old Aug 26, 2009 | 10:59 PM
  #34
WHITE_POWERSTROKE's Avatar
WHITE_POWERSTROKE
this information im about to share comes from technicians that i know both ones that work on the heavy duty semi's and light duty desiel pickups. i've been told tranny fluid is an excellent additive for multiple reasons. not only is it a good lubricant it is also a high detergent additive so it keeps your injectors and things of that nature clean. then from there it is also extremely flammable under pressure and has been known to increase the cetane level. i have also heard about the 2 stroke option but i heard from a handful of people that the 2 stroke will clog fuel filters and injectors not 100% sure sounds like you guys are having alot of success with it but here's a thought my buddies at ford run 80% used atf that they have filtered and 20% pump diesel in their trucks they run quieter and get approxametely 1.5 mpg better then on pump alone. just something to think about
Old Aug 27, 2009 | 12:33 AM
  #35
Rofflecat's Avatar
Rofflecat
Not sure if this might be something along the lines of what you're looking for... starting mostly around page 11.
http://mopar.mopar1973man.com/pdf/022003bosch.pdf
Old Aug 27, 2009 | 08:52 PM
  #36
IABill's Avatar
IABill
Aklim, Glad you at least took the time to read it.......
"Let me ask you this. If these snake oils do as much as the manufacturers like to think, why haven't they done a proper test instead of using these "studies" to infer you need their snake oil? After all, if you are selling it, isn't the onus on you to prove efficacy instead of trying to use these "studies" to hint at reasons why the consumer should buy their snake oil?"
What would you consider a proper test for lubricity if the High Frequency Reciprocating Rig test is not a "proper test" to measure lubricity of the tested "snake oils"?
I am not selling anything.
And it appears that the product that provides the best lubricity( REG's Biodiesel) and did not in any way fund this lab test......
Old Aug 28, 2009 | 07:49 AM
  #37
aklim's Avatar
aklim
Very interesting. Going to digest some of it later today.
Old Aug 28, 2009 | 07:55 AM
  #38
aklim's Avatar
aklim
From my initial reads, the item on the mopar board would be a good test. From an initial glance, it shows that there is a certain amount of increased wear in the pump parts. That shows things much better. Now I know that with say 520 fuel, I am probably losing 15-20% of pump life. Now I can calculate what the pump is worth and what the cost of additive and my time and decide if I want to dump the stuff in it.
Just showing the ball sliding up and down doesn't cut it. With the graph on page 11, you can see how much wear you are willing to put up with.
Old Aug 28, 2009 | 08:51 AM
  #39
Izzy351's Avatar
Izzy351
Don't forget to calculate the better burn rate if you use an additive with a cetane bump. I *do* notice about 1 mpg increase while using it. That's enough for me. Well, that, and better power due to the more complete burn.
Old Aug 28, 2009 | 02:29 PM
  #40
USAF CCM's Avatar
USAF CCM
Originally Posted by HKusp
Just so you know, I am NOT one of them. I also am not someone who will beat someone for money. I will do it for free and I doubt they will come away with a warm and fuzzy feeling afterward.
HeHeHe. HKusp, I like your style and the avatar!
Old Aug 28, 2009 | 02:53 PM
  #41
jjs1988's Avatar
jjs1988
this is sorta off yalls topic yall have merged to but i pulled up to a shell station virtually on my last drops yea its bad i know but i wanted to try this so i put 12 oz of that super tech 2 stroke oil in a few shots of dieselkleen and a full tank and literally when pulling out of the parking lot i significantly noticed a quieting when the new fuel hit the bowl i jus thought that was pretty frickin cool haha sorry for interupting
Old Aug 31, 2009 | 01:46 PM
  #42
snakyjake's Avatar
snakyjake
I’d like to see more studies on ATF. But at the same time, I don’t have access to a lot of ATF to burn. The reason why 2-stroke oil is so popular is because we can still drive up to any fuel station, and simply add a quart of cheap easily accessible 2-stroke oil.
We’re adding not just any 2-stroke oil, but TW3 2-stroke oil; extra additives and ashless.
As for clogging filters, I can’t imagine that being a problem at the ratio being used, and with using TW3. I don’t think 2-stroke oil will change the fuel viscosity to clog a filter, and there shouldn’t be anything in the oil to clog a filter. I’ve been using 50/50 2-stroke oil in my other gasoline engines, and never had a fuel filter clog.
I'm also careful about some of the fuel stations that say "Up to 5% biodiesel". I'm not sure if it is 0%, 1%, 2%, or 5% being added.
Thanks for your comments,
Jake
Old Aug 31, 2009 | 08:24 PM
  #43
Franko72's Avatar
Franko72
Molon Labe
Originally Posted by superduty4x4
I had been using gray bottle Diesel Kleen every tank for a while, 1 oz per 4 gallons of fuel. It took a while, but I did notice decreased injector noise over time. I recently switched to Supertech (Walmart) 2 stroke oil just for grins and have been using 1 oz per gallon of fuel. My truck has actually got noisier on the 2 stroke slightly (more so when cold), and it may be coincidence but the first big trip with 2 stroke oil in the tank my MPG's were in the crapper big time. I've only ran it for a few tanks, but so far I'm not real impressed and I think I'll switch back to DK once I run out of 2 stroke oil.
I too started adding 1oz of Supertech 2 stroke per gallon of diesel, for the last 3 tanks of fuel. The motor initially got quieter, now it seems to be louder...Its difficult to tell over the #8 injector tick, which also seems louder since I started the 2 stroke diet.
I do like the idea of adding some lube to the fuel system though. I think I'll run straight fuel next fillup and see and hear what happens.
bubba_3711
23
Aug 23, 2012 11:28 PM
Native Tex
Oct 21, 2011 01:07 PM
randomhero1172
6.4L Power Stroke Diesel
Nov 9, 2007 02:23 PM
sicdefused
Aerostar
Mar 30, 2007 05:12 PM
watson
General Diesel Discussion
Mar 11, 2007 10:02 PM
