adding lubricity?
Old Aug 25, 2009 | 01:49 PM
HKusp's Avatar
HKusp
Originally Posted by Izzy351
Think with your dipstick, jimmy!!
I would BEAT that guys azz if he hit me with a dip stick. In fact, I would probably beat him as soon as I saw him just on GP at this point.
Old Aug 25, 2009 | 02:04 PM
aklim's Avatar
aklim
But do you also deny the benefit of a cetane boost? That IS proven.
Cetane boost is a totally different story.
Old Aug 25, 2009 | 02:05 PM
aklim's Avatar
aklim
Originally Posted by brian42
And that's the "leading" dino against the Castrol "synthetic"...
Yep. Just 2 cars show up. No note of engine condition or anything. Was that leading dino with garbage in it in a crummy engine vs fresh Castrol synthetic? Nobody really knows.
Old Aug 25, 2009 | 02:06 PM
aklim's Avatar
aklim
Just so you know, some people pay money to get beaten.
Old Aug 25, 2009 | 02:08 PM
HKusp's Avatar
HKusp
Just so you know, I am NOT one of them. I also am not someone who will beat someone for money. I will do it for free and I doubt they will come away with a warm and fuzzy feeling afterward.
Old Aug 25, 2009 | 05:50 PM
Izzy351's Avatar
Izzy351
Now THAT'S thinkin' with yer dipstick!!
Old Aug 25, 2009 | 06:09 PM
jjs1988's Avatar
jjs1988
alright guys preciate all the good info ill run a little 2stroke oil in it and see if she quiets down a bit
Old Aug 25, 2009 | 09:42 PM
big poppa's Avatar
big poppa
Originally Posted by 03_PSD
I've always wanted to try some Bio, just can't find it close.
I hear yaa, where I used to live, none around, moved out here and theres a place 8 miles down the road, don't go anywhere else unless I travel away.
Old Aug 25, 2009 | 09:50 PM
nickj11's Avatar
nickj11
SuperTech (Wal-Mart) 2 strk outboard oil
I have a padnuh that was a Ford factory trained diesel tech (20yrs) on the 6.0 and back- real knowledgable w/ the 7.3- plus that's what he drives. He recommended adding 1 pint of supertech outboard motor oil to every tank full of fuel ( comes out to about 120:1 ratio ). Reason being- the older "true diesels" were designed to run on higher sulphur diesel- sulpher acts as a lubricant in diesel fuel. Nowadays, we all know we have to run ultra-low sulphur diesel- so, where's the lubricity ?? Alot of it's gone w/ the sulpher- most of it, actually. The newer diesels are designed for it- ours (the 7.3's) are not- we prolly need a little more lubricity- mine does definately to run smoother w/ it.
Old Aug 25, 2009 | 10:27 PM
Rofflecat's Avatar
Rofflecat
http://mopar.mopar1973man.com/tips/c...-cycle-oil.htm
Might provide an interesting read...
Old Aug 26, 2009 | 07:53 AM
aklim's Avatar
aklim
AFAIK, it is not the sulfur in this case that is really much of a lubricant. At least not in the levels it is at. It is the process of removing the sulfur that strips of some of the aromatic compounds that lubricate. Someone correct me if I am wrong.
Old Aug 26, 2009 | 08:15 AM
Izzy351's Avatar
Izzy351
You are correct. The process of removing the sulfur also removes the natural lubricity of the fuel. So in another extremely well thought out plan by a gov't agency, we have to pay to remove it, then pay extra to have it put back. Great plan, doncha think??
Old Aug 26, 2009 | 08:17 AM
  #28
aklim's Avatar
aklim
Absolutely fantastic plan. Just like a stockbroker, they make money on ever end. Oh, you lose. Tough. Better luck next time. Sure. These are they guys I trust to manage my healthcare, run GM and Chrysler, etc, etc. Yeah, right.
Old Aug 26, 2009 | 09:16 AM
  #29
superduty4x4's Avatar
superduty4x4
Great post, couldn't agree more!
Old Aug 26, 2009 | 12:51 PM
  #30
IABill's Avatar
IABill
Exclamation
If you want the straight data and I am not promoting this other site, but
this is the most comprehensive data I have ever seen. I printed a hard copy from dieselplace dot com. search for: lubricity additive study results. It was done at the southwest research lab in the great state of Texas.
Results were in order of best lubricity to least:
#1. REG 2% bio diesel blend with 98% pump diesel
#2. Opti Lube XPD 13oz per 26 gallons
#3 FPPF RV,Bus,SUV Diesel treatment 5.2oz per 26 gal
#4 Opti Lube summer blend multi purpose 1.11 oz per 26 gal
#5 Opti Lube winter blend 6.5 oz per.....
#6 Schaeffer Diesel treat 2000 3.32 oz per...
#7 Super Tech Outboard 2-cycle TC-3W 16.64 oz per....
#8 Stanadyne lubricity formula 3.32 oz per....
#9 Amsoil Diesel concentrate 5.2 oz per....
#10 Power Service Diesel Kleen + Cetane Boost 8.32 oz per....
There is a lot more there Tried to scan & copy but I cant get it to work...
