Solving an overheat problem
Old May 23, 2010 | 10:33 PM
  #181
sdetweil's Avatar
sdetweil
Originally Posted by Julies Cool F1
I think you'll also find it to be much more stable in holding temperature after you get about 4000-5000 miles on it.
After I got mine broken in, any temp climbs at idle after long runs stopped!
maybe... just crossed 200 miles..
sam
Old May 24, 2010 | 10:32 PM
  #182
fatfenders56's Avatar
fatfenders56
I am coming in kind of late on this but I had the same problem with a 351-C, I put a restrictor in the lower radiator hose to slow down the flow and keep the coolant in the radiator longer, dropped the temp 50 degrees, The coolant might be going too fast at highway speeds. There are some radiator shops that can tell you the flow rate for your engine and measure the flow through the radiator to see if they are close. LOL
Old May 24, 2010 | 11:33 PM
  #183
AXracer's Avatar
AXracer
A common cause of overheating at speed is not enough air going thru the radiator due to being blocked by deflectors, fan shrouds and even the fan itself (especially mechanically driven fans on vehicles with OD tranny and/or high rear end ratio for economy.The air gets stacked up in front of the radiator and spills around it instead of going thru it.
Old May 25, 2010 | 02:04 AM
  #184
Julies Cool F1's Avatar
Julies Cool F1
And another point to what AX said: What goes in must come out.
If there isn't enough room around the engine for the used, now expanded, hot air to flow out of the engine compartment aerodynamically, it will cause back pressure in front of the radiator and impede flow through it as well.
Old May 25, 2010 | 06:53 AM
  #185
sdetweil's Avatar
sdetweil
for me, with the restrictor instead of a real thermostat, the temp dropped to 160 while driving and rose to 195 sitting.. 160 is too cold.
So I installed a good thermostat in place of the restrictor.
Sam
Old May 25, 2010 | 03:50 PM
  #186
AXracer's Avatar
AXracer
Yes sometimes the engineers actually do get it right. It's when we start modifying their carefully balanced systems things sometimes start going haywire. Then we compound the problems we made by throwing a bunch of "solutions" at it all at once. We then don't know what helped or what hurt. Making changes one at a time and evaluating the results is typically cheaper and easier than accidently "fixing" it or using a Rube Goldberg "band aid". Sam reverse engineered his problem, the second best way, by then removing his fixes one at a time to see which change was the real solution. That is much better than leaving a shotgun blast of fixes in place since "throwing a bunch of ropes into a room with a snake may hide the snake for a while, but sooner or later you may still get bit".
Old May 25, 2010 | 04:18 PM
  #187
sdetweil's Avatar
sdetweil
and it is SO hard to un-convince yourself that 'new' parts cannot be related to the problem.. the first posts in response to my initial report said 'theormostat', but I had convinced myself this could not be the problem.. and I had tested it for the typical conditions, open & close at the right temps.. I just didn't see the flow impact effect..
I spent a lot of time and energy (from all of you as well, (y'all in texas speak)) and money to avoid a $6 problem.
Sam
T Biscuit
Feb 2, 2017 09:08 AM
waituntilthebeep
35
Mar 13, 2016 08:35 AM
WhiteBeast-05-powers
Mar 12, 2016 08:13 PM
jonnydz
Sep 2, 2015 01:05 PM
mac01
Jul 4, 2014 07:10 PM
