e4od tranny cooler ?
Old Jul 3, 2014 | 08:46 PM
mac01's Avatar
mac01
So I'm thinking when the tranny was replaced before I bought it they put an aftermarket cooler on it and bypassed the radiator.. it seems to run warmer than I think it should like 180ish not pulling anything and alot warmer when pulling. Btw it's a 96 f350.
My question is why would they do this? Contamination from when the old tranny blew maybe??? If that's the case can the rad be flushed and hooked up in conjunction with the aftermarket cooler or would I be looking at a new rad because of the risk of contamination?
Old Jul 3, 2014 | 09:04 PM
oldbird1965's Avatar
oldbird1965
I had to buy a new radiator once because I blew the trans and the radiator was contaminated. Yes, the radiator should be used as part of the cooling.
Old Jul 3, 2014 | 09:22 PM
mac01's Avatar
mac01
I'm guessing it's not safe to flush one?
Old Jul 4, 2014 | 01:24 AM
fordman67's Avatar
fordman67
Use some hose to direct the flush material into a cup or jar.flush both directions with solvent and compressed air.if you get no metal in either direction then it might be OK.many trans shops do the reroute just because and IMO don't know any better.also jasper used to require it for their warranty.
Old Jul 4, 2014 | 11:10 AM
IDMooseMan's Avatar
IDMooseMan
I would flush it and use in conjunction with the aftermarket cooler. The integrated transmission cooler is a very effective component by itself. Adding an "extra" cooling component is a great idea, especially if you're towing heavy.
Old Jul 4, 2014 | 02:56 PM
mac01's Avatar
mac01
Thanks guys.. I think I'll try to flush it cuz I'm just not happy with my temps and would like to make it last as long as I can. Now just to figure out the easiest way to flush it.
Old Jul 4, 2014 | 06:10 PM
427 fordman's Avatar
427 fordman
They make an aerosol type can that hooks onto the lines you can flush with. I used a couple of them to flush my radiator before I put my rebuilt trans in. The old one didn't quit, I just upgraded and wanted to clean the radiator out as good as I could.
Old Jul 4, 2014 | 07:10 PM
fordman67's Avatar
fordman67
I just shoot a crap load of brake Klein in then compressed air..it makes a good mess if you aren't careful lol
djmichael24951
27
Feb 5, 2014 06:29 PM
bogie346
Aug 16, 2011 08:15 AM
Franko72
Aug 11, 2010 05:12 PM
njstevens
Mar 22, 2010 08:58 AM
wolverineflight31
Jun 9, 2003 12:50 PM
